Rates of convergence for robust geometric inference - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Statistics Année : 2016
Distances to compact sets are widely used in the field of Topological Data Analysis for inferring geometric and topological features from point clouds. In this context, the distance to a probability measure (DTM) has been introduced by Chazal et al. (2011b) as a robust alternative to the distance a compact set. In practice, the DTM can be estimated by its empirical counterpart, that is the distance to the empirical measure (DTEM). In this paper we give a tight control of the deviation of the DTEM. Our analysis relies on a local analysis of empirical processes. In particular, we show that the rate of convergence of the DTEM directly depends on the regularity at zero of a particular quantile function which contains some local information about the geometry of the support. This quantile function is the relevant quantity to describe precisely how difficult is a geometric inference problem. Several numerical experiments illustrate the convergence of the DTEM and also confirm that our bounds are tight.
DTM-V3.pdf (916.36 Ko) Télécharger le fichier
hal-01336913 , version 1 (24-06-2016)
hal-01336913 , version 2 (19-10-2016)
  • HAL Id : hal-01336913 , version 1
F Chazal, P Massart, B Michel. Rates of convergence for robust geometric inference. Electronic Journal of Statistics , 2016, 10 (2), pp.44. ⟨hal-01336913v1⟩
232 Consultations
191 Téléchargements
