Conference papers
A Look at Basics of Distributed Computing *
Michel Raynal 1, 2, *
* Corresponding author
2 ASAP - As Scalable As Possible: foundations of large scale dynamic distributed systems
Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : This paper presents concepts and basics of distributed computing which are important (at least from the author's point of view), and should be known and mastered by Master students and engineers. Those include: (a) a characterization of distributed computing (which is too much often confused with parallel computing); (b) the notion of a synchronous system and its associated notions of a local algorithm and message adversaries; (c) the notion of an asynchronous shared memory system and its associated notions of universality and progress conditions; and (d) the notion of an asynchronous message-passing system with its associated broadcast and agreement abstractions, its impossibility results, and approaches to circumvent them. Hence, the paper can be seen as a guided tour to key elements that constitute basics of distributed computing.
Complete list of metadata
Cited literature [67 references]  Display  Hide  Download
https://hal.inria.fr/hal-01337523
Contributor : Michel Raynal Connect in order to contact the contributor
Submitted on : Monday, June 27, 2016 - 9:32:00 AM
Last modification on : Saturday, June 25, 2022 - 7:45:05 PM
Long-term archiving on: : Wednesday, September 28, 2016 - 10:52:07 AM
File
RR-ICDCS-2016.pdf
Identifiers
  • HAL Id : hal-01337523, version 1
Citation
Michel Raynal. A Look at Basics of Distributed Computing *. EEE ICDCS 2016 - 36th International Conference on Distributed Computing Systems, Jun 2016, Nara, Japan. ⟨hal-01337523⟩
Share
Metrics
Record views
282
Files downloads
970
