Towards a hardware-assisted information flow tracking ecosystem for ARM processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work details a hardware-assisted approach for information flow tracking implemented on reconfigurable chips. Current solutions are either time-consuming or hardly portable (modifications of both software/hardware layers). This work takes benefits from debug components included in ARMv7 processors to retrieve details on instructions committed by the CPU. First results in terms of silicon area and time overheads are also given.
fpl2016.pdf (195.97 Ko) Télécharger le fichier
hal-01337579 , version 1 (29-06-2016)
Muhammad Abdul Wahab, Pascal Cotret, Mounir Nasr Allah, Guillaume Hiet, Vianney Lapotre, et al.. Towards a hardware-assisted information flow tracking ecosystem for ARM processors. 26th International Conference on Field-Programmable Logic and Applications (FPL 2016), Aug 2016, Lausanne, Switzerland. ⟨10.1109/fpl.2016.7577396⟩. ⟨hal-01337579⟩
558 Consultations
428 Téléchargements
