sfc(G) = 0. ii) By the equivalence between i) and iv) in Theorem 29, for the graph G with at least 4 vertices, it holds H(G) ? 2 if and only if G is not Hamiltonian-connected, which then amounts to saying that src(G) = sfc(G) = 0. iii) On account of H(G) ? 3, Theorem 29 i) ? iv) shows that G is spanning 1-rail-connected while Theorem 30 implies that G is spanning q-rail-connected for all q , H(G)}. Finally, the equivalence between a) and g) in Theorem 22 tells us that G cannot be spanning (H(G) + 1)-rail-connected. This completes the proof of src(G) = H(G) It follows from Theorem 29 i) ? ii) that sfc(G) ? H(G) ? 1. On the other hand, Theorem 29 iii) ? i) claims that sfc(G) ? H(G) ? 1. Accordingly, we get to H(G) = sfc(G) + 1. Proof of Lemma 38: This follows from the equivalence of c) and g) in Theorem 22 Theorem 11) asserted that every connected rigid interval graph has a so-called consecutive ordering of its vertex set, which must correspond to a Hamiltonian path. Proof of Theorem 40: Recall that every connected unit interval graph is a rigid interval graph Therefore, Lemma 39 tells us that unit interval graphs form a maroon class of interval graphs. The result is now a simple consequence of Lemma 38 Theorem 10) showed that ?(G) = 2 t(G) holds for every connected noncomplete K 1,3 -free graph G while Roberts (94) told us that every unit interval graph is K 1,3 -free. Combining these with Eq, Panda and Das Theorems 33 and 40 then conclude the proof. Note that we can avoid using Matthews and Sumner Theorem 10) by directly proving 2 t(G) = min CC ?E(T ) |C ? C | where T is a clique path of the connected noncomplete unit interval graph G. Proof of Theorem 42: Let G be a Hamiltonian) and CASE 1. H(G) = H G (?) > 0. Let S = {? j : ? j ? N G (? f G (?) ), j > f G (?)}. From Theorem 44 and Eq. (55) we derive H(G ? S ) = H(G) ? |S | = 0 ,
This proves that S ? S is a scattering set of G ,
On 3 * -connected graphs, Australasian Journal of Combinatorics, vol.24, pp.193-208, 2001. ,
Linear algorithm for optimal path cover problem on interval graphs, Information Processing Letters, vol.35, issue.3, pp.149-153, 1990. ,
DOI : 10.1016/0020-0190(90)90064-5
The 1-Fixed-Endpoint Path Cover Problem is??Polynomial on Interval Graphs, Algorithmica, vol.18, issue.3, pp.679-710, 2010. ,
DOI : 10.1007/s00453-009-9292-5
Riemann-Roch and Abel-Jacobi theory on a finite graph Advances in Mathematics, pp.766-788, 2007. ,
Early Writings on Graph Theory: Hamiltonian Circuits and The Icosian Game, Resources for Teaching Discrete Mathematics: Classroom Projects, History Modules and Articles, pp.217-223, 2009. ,
DOI : 10.5948/UPO9780883859742.028
Toughness and Vertex Degrees, Journal of Graph Theory, vol.17, issue.2, pp.209-219, 2013. ,
DOI : 10.1002/jgt.21639
URL : http://arxiv.org/abs/0912.2919
Finding Hamiltonian circuits in proper interval graphs, Information Processing Letters, vol.17, issue.2, pp.97-101, 1983. ,
DOI : 10.1016/0020-0190(83)90078-9
Graph Theory, 2008. ,
DOI : 10.1007/978-1-84628-970-5
How many conjectures can you stand? A survey. Graphs and Combinatorics, pp.57-75 ,
Linear-Time Algorithms for Scattering Number and Hamilton-Connectivity of Interval Graphs, Proceedings of the 39th International Workshop on Graph-Theoretic Concepts in Computer Science, pp.127-138978, 2013. ,
DOI : 10.1007/978-3-642-45043-3_12
Hamiltonicity of k-traceable graphs, Electronic Journal of Combinatorics, vol.18, 2011. ,
Powers of asteroidal triple-free graphs with applications, Ars Combinatoria, vol.67, pp.161-173, 2003. ,
n-Hamiltonian graphs, Journal of Combinatorial Theory, vol.9, issue.3, pp.308-312, 1970. ,
DOI : 10.1016/S0021-9800(70)80069-2
Connected proper interval graphs and the guard problem in spiral polygons, Combinatorics and Computer Science Lecture Notes in Computer Science, vol.1120, pp.39-47, 1996. ,
DOI : 10.1007/3-540-61576-8_71
On strongly hamiltonian abelian group graphs, Combinatorial Mathematics VIII, Proceedings of the Eighth Australian Conference, pp.23-34, 1980. ,
DOI : 10.1007/978-1-349-03521-2
Proper interval graphs and the guard problem, Discrete Mathematics, vol.170, issue.1-3, pp.223-230, 1997. ,
DOI : 10.1016/S0012-365X(96)00307-X
New conditions for k-ordered Hamiltonian graphs, Ars Combinatoria, vol.70, 2004. ,
Cycle Extendability of Hamiltonian Interval Graphs, SIAM Journal on Discrete Mathematics, vol.20, issue.3, pp.682-689, 2006. ,
DOI : 10.1137/S0895480104441450
Optimally Balanced Forward Degree Sequence, Computing and Combinatorics, pp.680-689, 2005. ,
DOI : 10.1007/11533719_69
On Spanning Disjoint Paths in Line Graphs, Graphs and Combinatorics, vol.22, issue.51, pp.1721-1731, 2013. ,
DOI : 10.1007/s00373-012-1237-0
Planar orientations with low out-degree and compaction of adjacency matrices, Theoretical Computer Science, vol.86, issue.2, pp.243-266, 1991. ,
DOI : 10.1016/0304-3975(91)90020-3
A note on Hamiltonian circuits, Discrete Mathematics, vol.2, issue.2, pp.111-113 ,
DOI : 10.1016/0012-365X(72)90079-9
Linear Orderings of Subfamilies of AT???Free Graphs, SIAM Journal on Discrete Mathematics, vol.20, issue.1, pp.105-118, 2006. ,
DOI : 10.1137/S0895480104445307
LDFS-Based Certifying Algorithm for the Minimum Path Cover Problem on Cocomparability Graphs, SIAM Journal on Computing, vol.42, issue.3, pp.792-807, 11083856. ,
DOI : 10.1137/11083856X
URL : https://hal.archives-ouvertes.fr/hal-00936300
My Graph, Proceedings of the London Mathematical Society, Third Series, pp.117-136, 1983. ,
DOI : 10.1112/plms/s3-46.1.117
Paths in interval graphs and circular arc graphs, Discrete Mathematics, vol.112, issue.1-3, pp.49-64, 1993. ,
DOI : 10.1016/0012-365X(93)90223-G
Finding Hamiltonian paths in cocomparability graphs using the bump number algorithm. Order, pp.383-391, 1991. ,
A survey of graphs Hamiltonian-connected from a vertex, Graph Theory, Combinatorics, and Applications Proceedings of the Sixth Quadrennial International Conference on the Theory and Applications of Graphs held at Western Michigan University, pp.297-313, 1988. ,
1-Tough cocomparability graphs are hamiltonian, Discrete Mathematics, vol.170, issue.1-3, pp.99-106, 1997. ,
DOI : 10.1016/0012-365X(95)00359-5
On rigid circuit graphs, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.13, issue.1-2, pp.71-76, 1961. ,
DOI : 10.1007/BF02992776
On chromatic number of graphs and set-systems, Acta Mathematica Academiae Scientiarum Hungaricae, vol.24, issue.66, pp.61-99, 1966. ,
DOI : 10.1007/BF02020444
Characterizations of strongly chordal graphs, Discrete Mathematics, vol.43, issue.2-3, pp.173-189, 1983. ,
DOI : 10.1016/0012-365X(83)90154-1
Optimal Hamiltonian completions and path covers for trees, and a reduction to maximum flow, The ANZIAM Journal, vol.9, issue.02, pp.193-204, 2002. ,
DOI : 10.1016/0020-0190(76)90080-6
Solution du probl'e me no. 29. Revue Française d'Informatique et de, Recherche Opérationnelle, vol.8, pp.214-218, 1964. ,
Scattering number and modular decomposition, Discrete Mathematics, vol.165, issue.166, pp.165-166321, 1997. ,
DOI : 10.1016/S0012-365X(96)00180-X
On P4-tidy graphs, Discrete Mathematics & Theoretical Computer Science, vol.1, issue.1, pp.17-41, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-00955688
Algorithmic Graph Theory and Perfect Graphs, Annals of Discrete Mathematics . Elsevier Science B.V, vol.57, 2004. ,
A look at cycles containing specified elements of a graph, Discrete Mathematics, vol.309, issue.21, pp.6299-6311, 2009. ,
DOI : 10.1016/j.disc.2008.04.017
Edge fault tolerance in graphs, Networks, vol.8, issue.2, pp.135-142, 1993. ,
DOI : 10.1002/net.3230230207
Extending cycles in graphs, Discrete Mathematics, vol.85, issue.1, pp.59-72, 1990. ,
DOI : 10.1016/0012-365X(90)90163-C
Counting clique trees and computing perfect elimination schemes in parallel, Information Processing Letters, vol.31, issue.2, pp.61-68, 1989. ,
DOI : 10.1016/0020-0190(89)90070-7
On the extremal number of edges in hamiltonian connected graphs, Applied Mathematics Letters, vol.23, issue.1, pp.26-29, 2010. ,
DOI : 10.1016/j.aml.2009.03.025
Hamiltonicity in graphs with few P4 s. Computing, pp.213-225, 1995. ,
Fault-free Hamiltonian cycles in faulty arrangement graphs, IEEE Transactions on Parallel and Distributed Systems, vol.10, issue.3, pp.223-237, 1999. ,
DOI : 10.1109/71.755822
On container width and length in graphs, groups, and networks. IE- ICE Transactions Fundamentals of Electronics, Communications and Computer Sciences, issue.4, pp.77-668, 1994. ,
Graph Theory and Interconnection Networks, 2009. ,
Hamilton connectivity of line graphs and claw-free graphs, Journal of Graph Theory, vol.89, issue.2, pp.130-141, 2005. ,
DOI : 10.1002/jgt.20099
The spanning connectivity of line graphs, Applied Mathematics Letters, vol.24, issue.9, pp.1614-1617, 2011. ,
DOI : 10.1016/j.aml.2011.04.013
Linear-time certifying algorithms for the path cover and Hamiltonian cycle problems on interval graphs, Applied Mathematics Letters, vol.24, issue.5, pp.648-652, 2011. ,
DOI : 10.1016/j.aml.2010.11.030
The clique-separator graph for chordal graphs, Discrete Applied Mathematics, vol.157, issue.8, pp.1737-1749, 2009. ,
DOI : 10.1016/j.dam.2009.02.006
The Longest Path Problem has a Polynomial Solution on Interval Graphs, Algorithmica, vol.377, issue.2, pp.320-341, 2011. ,
DOI : 10.1007/s00453-010-9411-3
Powers of Hamiltonian paths in interval graphs ISSN 1097-0118. doi: 10.1002/(SICI), 1<31::AID-JGT3>3.0.CO, pp.31-381097, 1998. ,
A catalogue of small maximal nonhamiltonian graphs, Discrete Mathematics, vol.39, issue.2, pp.229-234, 1982. ,
DOI : 10.1016/0012-365X(82)90145-5
Paired many-to-many disjoint path covers in faulty hypercubes, Theoretical Computer Science, vol.513, pp.1-24, 2013. ,
DOI : 10.1016/j.tcs.2013.10.008
On a class of posets and the corresponding comparability graphs, Journal of Combinatorial Theory, Series B, vol.24, issue.2, pp.125-133, 1978. ,
DOI : 10.1016/0095-8956(78)90013-8
On the cube of a graph, Bulletin canadien de math??matiques, vol.11, issue.0, pp.295-296, 1968. ,
DOI : 10.4153/CMB-1968-037-0
On k???ordered Hamiltonian graphs, 1<17::AID-JGT2>3.0.CO, pp.17-25, 1999. ,
DOI : 10.1002/(SICI)1097-0118(199909)32:1<17::AID-JGT2>3.3.CO;2-7
The Linkage of a Graph, SIAM Journal on Computing, vol.25, issue.3, pp.626-647, 1996. ,
DOI : 10.1137/S0097539793255709
Domination on Cocomparability Graphs, SIAM Journal on Discrete Mathematics, vol.6, issue.3, pp.400-417, 1993. ,
DOI : 10.1137/0406032
Computing the toughness and the scattering number for interval and other graphs, INRIA Rennes, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00074433
Toughness, hamiltonicity and split graphs, Discrete Mathematics, vol.150, issue.1-3, pp.231-245, 1996. ,
DOI : 10.1016/0012-365X(95)00190-8
-Hamiltonian Line Graphs, Journal of Graph Theory, vol.89, issue.3, pp.344-358, 2013. ,
DOI : 10.1002/jgt.21713
URL : https://hal.archives-ouvertes.fr/hal-01009120
Hamiltonian Connected Line Graphs, Discrete Mathematics, vol.308, issue.18, pp.4293-4297, 2008. ,
DOI : 10.1007/978-3-540-72588-6_61
On the existence of certain configurations within graphs and the 1-skeleons of polytopes, Proceedings of the London Mathematical Society, vol.20, pp.144-160, 1974. ,
General-demand disjoint path covers in a graph with faulty elements, International Journal of Computer Mathematics, vol.33, issue.10, pp.606-617, 2012. ,
DOI : 10.1016/j.ipl.2004.05.013
Maximal Neighborhood Search and Rigid Interval Graphs, Journal of Graph Algorithms and Applications, vol.17, issue.3, pp.245-264, 2013. ,
DOI : 10.7155/jgaa.00293
A linear time algorithm for the 1-fixed-endpoint path cover problem on interval graphs. submitted, 2014 ,
$k$-degenerate graphs, Journal canadien de math??matiques, vol.22, issue.0, pp.1082-1096, 1970. ,
DOI : 10.4153/CJM-1970-125-1
On the spanning connectivity of graphs, Discrete Mathematics, vol.307, issue.2, pp.285-289, 2007. ,
DOI : 10.1016/j.disc.2006.06.021
On spanning connected graphs, Discrete Mathematics, vol.308, issue.7, pp.1330-1333, 2008. ,
DOI : 10.1016/j.disc.2007.03.072
On the spanning fan-connectivity of graphs, Discrete Applied Mathematics, vol.157, issue.7, pp.1342-1348, 2009. ,
DOI : 10.1016/j.dam.2008.11.014
Homomorphieeigenschaften und mittlere Kantendichte von Graphen, Mathematische Annalen, vol.153, issue.215, pp.265-268, 1967. ,
DOI : 10.1007/BF01364272
An optimum ??(n log n) algorithm for finding a canonical hamiltonian path and a canonical hamiltonian circuit in a set of intervals, Information Processing Letters, vol.35, issue.4, pp.205-211, 1990. ,
DOI : 10.1016/0020-0190(90)90025-S
Hamiltonian results inK1,3-free graphs, Journal of Graph Theory, vol.82, issue.1, pp.139-146, 1984. ,
DOI : 10.1002/jgt.3190080116
A Simple Polynomial Algorithm for the Longest Path Problem on Cocomparability Graphs, SIAM Journal on Discrete Mathematics, vol.26, issue.3, pp.940-963 ,
DOI : 10.1137/100793529
Hamilton cycle and Hamilton path extendability of Cayley graphs on abelian groups, Journal of Graph Theory, vol.40, issue.4 ,
DOI : 10.1002/jgt.20621
On a problem of Ore. The Mathematical Gazette, pp.40-41, 1965. ,
k-Ordered Hamiltonian graphs ISSN 1097-0118. doi: 10.1002/(SICI), 1<45::AID-JGT6>3.0.CO, pp.45-571097, 1997. ,
Every connected, locally connected nontrivial graph with no induced claw is hamiltonian, Journal of Graph Theory, vol.98, issue.4, pp.351-356, 1979. ,
DOI : 10.1002/jgt.3190030405
Hamiltonian connected graphs, Journal de Mathématiques Pures et Appliquées Neuviéme Série, vol.42, pp.21-27, 1963. ,
Hamiltonian cycles and dominating cycles passing through a linear forest, Discrete Mathematics, vol.309, issue.6, pp.1584-1592, 2009. ,
DOI : 10.1016/j.disc.2008.02.031
A parallel algorithm for generating bicompatible elimination orderings of proper interval graphs, Information Processing Letters, vol.109, issue.18, pp.1041-1046, 2009. ,
DOI : 10.1016/j.ipl.2009.06.011
Single-source three-disjoint path covers in cubes of connected graphs, Information Processing Letters, vol.113, issue.14-16, pp.14-16527, 2013. ,
DOI : 10.1016/j.ipl.2013.04.012
Many-to-many disjoint path covers in hypercube-like interconnection networks with faulty elements, IEEE Transactions on Parallel and Distributed Systems, vol.17, issue.3, pp.227-240, 2006. ,
DOI : 10.1109/TPDS.2006.37
On the circuits of finite graphs, Magyar Tud. Akad. Mat. Kutató Int. Közl, vol.8, pp.355-361, 1964. ,
On powers of interval and unit interval graphs, Congressus Numerantium, vol.59, pp.235-242, 1987. ,
Indifference graphs, Proof Techniques in Graph Theory, pp.139-146, 1969. ,
Graph Minors .XIII. The Disjoint Paths Problem, Journal of Combinatorial Theory, Series B, vol.63, issue.1, pp.65-110, 1995. ,
DOI : 10.1006/jctb.1995.1006
URL : http://doi.org/10.1006/jctb.1999.1919
Spanning connectivity of the power of a graph and Hamilton-connected index of a graph. Graphs and Combinatorics, pp.1551-1563, 2014. ,
Measures of traceability in graphs, Mathematica Bohemica, vol.131, issue.1, pp.63-84, 2006. ,
Chv??tal???Erd??s Theorem: Old Theorem with New Aspects, Computational Geometry and Graph Theory, pp.191-200, 2008. ,
DOI : 10.1002/jgt.3190120211
A Survey of Combinatorial Gray Codes, SIAM Review, vol.39, issue.4, pp.605-629, 1997. ,
DOI : 10.1137/S0036144595295272
On an ordering of the set of vertices of a connected graph. Publication of the Faculty of Sciences of the University of Brn?, pp.137-142, 1960. ,
An $O(n^2 \log n)$ Algorithm for the Hamiltonian Cycle Problem on Circular-Arc Graphs, SIAM Journal on Computing, vol.21, issue.6, pp.1026-1046, 1992. ,
DOI : 10.1137/0221061
On k-rails in graphs, Journal of Combinatorial Theory, Series B, vol.17, issue.2, pp.143-159, 1974. ,
DOI : 10.1016/0095-8956(74)90082-3
On the 1-fault hamiltonicity for graphs satisfying Ore??s theorem, Information Processing Letters, vol.112, issue.21, pp.839-843, 2012. ,
DOI : 10.1016/j.ipl.2012.07.014
On planar hypohamiltonian graphs, Journal of Graph Theory, vol.55, issue.1, pp.55-68, 2011. ,
DOI : 10.1002/jgt.20513
List colourings of graphs, pp.269-301, 2001. ,
DOI : 10.1017/CBO9780511721328.012
Hamiltonian thickness and fault-tolerant spanning rooted path systems of graphs, 2015. ,
