Multi-fragment effects on the gpu using the k-buffer, Proceedings of the 2007 symposium on Interactive 3D graphics and games, pp.97-104, 2007. ,
Order independent transparency with dual depth peeling, NVIDIA OpenGL SDK, pp.1-12, 2008. ,
Physically-based shading at disney, ACM SIGGRAPH (2012), pp.1-7 ,
X-Toon: An extended toon shader, International Symposium on Non-Photorealistic Animation and Rendering (NPAR'06), p.5, 2006. ,
The a -buffer, an antialiased hidden surface method, Proceedings of the 11th Annual Conference on Computer Graphics and Interactive Techniques SIG- GRAPH '84, pp.103-108, 1984. ,
Smart transparency for illustrative visualization of complex flow surfaces. Visualization and Computer Graphics, IEEE Transactions on, vol.19, issue.5, pp.838-851, 2013. ,
Suggestive contours for conveying shape, Proc. SIGGRAPH), pp.848-855, 2003. ,
A nonphotorealistic lighting model for automatic technical illustration, Proceedings of the 25th annual conference on Computer graphics and interactive techniques, pp.447-452, 1998. ,
Opacity optimization for surfaces, pp.11-20 ,
Enhancing surface features with the radiance scaling meshlab plugin, Computer Applications and Quantitative Methods in Archaeology (CAA) 2012 of Archaeology in the Digital Era, pp.417-421, 2012. ,
Iris: Illustrative rendering for integral surfaces. Visualization and Computer Graphics, IEEE Transactions on, vol.16, issue.2, pp.1319-1328, 2010. ,
Apparent ridges for line drawing, ACM SIGGRAPH 2007 Papers SIGGRAPH '07, p.7, 2007. ,
Demarcating curves for shape illustration, In ACM Transactions on Graphics (TOG), vol.27, issue.2, pp.157-164, 2008. ,
Order independent transparency in opengl 4.x, GPU Technology Conference (GTC), p.3, 2014. ,
Curvature-based transfer functions for direct volume rendering: Methods and applications, Visualization, 2003. VIS 2003, pp.513-520, 2003. ,
Ridge-valley lines on meshes via implicit surface fitting, ACM Transactions on Graphics (TOG), vol.23, issue.2, pp.609-612, 2004. ,
Exaggerated shading for depicting shape and detail, ACM SIGGRAPH 2006 Papers SIGGRAPH '06, pp.1199-1205, 2006. ,
The lit sphere: A model for capturing npr shading from art, Graphics interface, pp.143-150, 2001. ,
Comprehensible rendering of 3-d shapes, Proceedings of the 17th Annual Conference on Computer Graphics and Interactive Techniques SIG- GRAPH '90, pp.197-206, 1990. ,
Light Warping for Enhanced Surface Depiction, Proceedings of SIGGRAPH 2009, pp.3-4, 2009. ,
Radiance Scaling for Versatile Surface Enhancement, I3D '10: Proc. symposium on Interactive 3D graphics and games, p.5, 2010. ,
A multiview and multilayer approach for interactive ray tracing, Proceedings of the 20th ACM SIGGRAPH Symposium on Interactive 3D Graphics and Games I3D '16, ACM, pp.171-178 ,
Realtime concurrent linked list construction on the gpu, In Computer Graphics Forum, vol.29, issue.2, pp.1297-1304, 2010. ,
