Parallel Surface Reconstruction for Particle-Based Fluids, Computer Graphics Forum, issue.8, 2012. ,
Adaptively sampled particle fluids, ACM Trans. Graph, vol.26, issue.2, p.3, 2007. ,
A level-set method for skinning animated particle data, IEEE Transactions on Visualization and Computer Graphics, vol.21, issue.3 2, pp.315-327, 2015. ,
Combining implicit surfaces with soft blending in a CSG tree, Proc. of CSG Conference Series, pp.17-31, 1998. ,
Convolution surfaces, ACM SIGGRAPH '91, pp.251-256, 1991. ,
Extended field functions for soft objects, Proc. of Implicit Surfaces 1995, pp.21-32, 1995. ,
DualSPHysics: Open-source parallel CFD solver based on Smoothed Particle Hydrodynamics (SPH), Computer Physics Communications, vol.187, pp.0-204, 2015. ,
DOI : 10.1016/j.cpc.2014.10.004
Adequate Inner Bound for Geometric Modeling with Compact Field Function. Computer & Graphics (proceedings of SMI 2013, pp.565-573, 2013. ,
Locally restricted blending of Blobtrees, Computers & Graphics, vol.33, issue.6, pp.690-697, 2009. ,
DOI : 10.1016/j.cag.2009.04.007
A gradient-based implicit blend, ACM Transactions on Graphics, vol.32, issue.2, pp.1-12, 2013. ,
DOI : 10.1145/2451236.2451238
Smoothed particle hydrodynamics: theory and application to non-spherical stars, Monthly Notices of the Royal Astronomical Society, vol.181, issue.3 1, pp.375-389, 1977. ,
Controlled blending for implicit surfaces using a graph, Proc. of Implicit Surfaces 1995, pp.107-112, 1995. ,
Field functions for blending range controls on soft objects, Proc. of Eurographics, pp.233-242, 2003. ,
SPH Fluids in Computer Graphics, Eurographics 2014 -State of the Art Reports, 2014. ,
Particle-based fluid simulation for interactive applications, Proceedings of SIG- GRAPH/Eurographics Symposium on Computer Animation, pp.154-159, 2003. ,
Particle-based fluid-fluid interaction, Proceedings of SIG- GRAPH/Eurographics Symposium on Computer Animation, pp.237-244, 2005. ,
A unified particle model for fluid-solid interactions, Computer Animation and Virtual Worlds, vol.18, issue.2, p.10, 2007. ,
Data structure for soft objects, The Visual Computer, pp.227-234, 1986. ,
Better blending of implicit objects at different scales, ACM Siggraph, issue.2, 2000. ,
Reconstructing surfaces of particle-based fluids using anisotropic kernels, Proceedings of SIGGRAPH/Eurographics Symposium on Computer Animation SCA '10, Eurographics Association, pp.217-225, 2010. ,
Reconstructing surfaces of particle-based fluids using anisotropic kernels, ACM Trans. Graph, vol.32, issue.1 2, pp.1-12, 2013. ,
Animating sand as a fluid, ACM Trans. Graph, vol.24, issue.3, pp.965-972, 2005. ,
