Estimation of risk measures for extreme pluviometrical measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many risk measures can be found in the literature such as the Value-at-Risk and the Conditional Tail Expectation. In statistical terms, the Value-at-Risk is aquantile of the distribution of the variable of interest. In hydrology, the Value-at-Risk of the rainfall distribution is the return level. The Conditional Tail Expectation is the mean of the rainfalls larger than the Value-at-Risk. Here, we focus on the properties of these risk measures in case of extreme rainfall modeled by heavy-tailed distributions. In order to take into account the geographical factors, we also assume that these risk measures depend on a covariate. We present the theoretical properties of our estimators and we illustrate their behaviour on a real data set of daily rainfalls in the Cévennes-Vivarais region.
Fichier non déposé
hal-01340774 , version 1 (01-07-2016)
  • HAL Id : hal-01340774 , version 1
Jonathan El Methni, Laurent Gardes, Stéphane Girard. Estimation of risk measures for extreme pluviometrical measurements. Workshop "Extreme value modeling and water ressources", 2016, Aussois, France. ⟨hal-01340774⟩
261 Consultations
0 Téléchargements
