Logaritmo discreto en campos finitos de característica pequeña: atacando la criptogrfía basada en emparejamientos de tipo 1, Discrete logarithms in the cryptographically-interesting field GF(3 6 * 509, 2016. ,
Computing discrete logarithms in cryptographically-interesting characteristic-three finite fields, Cryptology ePrint Archive, 2016. ,
, Number Theory list, item 004923, 2016.
Computing discrete logarithms in F 3 6·137 and F 3 6·163 using Magma, Arithmetic of Finite Fields, PAIRING, vol.9061, pp.20-44, 2013. ,
Weakness of F 6 6·1429 and F 2 4·3041 for discrete logarithm cryptography, Finite Fields and Their Applications, vol.32, pp.148-170, 2015. ,
The function field sieve, Algorithmic Number Theory, vol.877, pp.141-154, 1994. ,
Function field sieve method for discrete logarithms over finite fields, Information and Computation, vol.151, pp.5-16, 1999. ,
Algorithmes de logarithmes discrets dans les corps finis, thèse de doctorat, 2013. ,
An appendix for a recent paper of Kim, Cryptology ePrint Archive, 1076. ,
Improving NFS for the discrete logarithm problem in non-prime finite fields, EUROCRYPT 2015, LNCS, vol.9056, pp.129-155, 2015. ,
A heuristic quasipolynomial algorithm for discrete logarithm in finite fields of small characteristic, LNCS, vol.8441, pp.1-16, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00835446
, The tower number field sieve, ASIACRYPT 2015, Part II, vol.9453, pp.31-55, 2015.
Computing logarithms in finite fields of characteristic two, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.2, pp.276-285, 1984. ,
Computing logarithms in GF(2 n ), CRYPTO'84, LNCS, vol.196, pp.73-82, 1984. ,
An algorithm to solve the discrete logarithm problem with the number field sieve, LNCS, vol.3958, pp.174-190, 2006. ,
, Discrete logarithms in GF(p), vol.1, pp.1-15, 1986.
Applications of theta functions for hyperelliptic curve cryptography, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00642951
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, pp.644-654, 1976. ,
A rigorous proof of the Waterloo algorithm for the discrete logarithm problem, Designs, Codes and Cryptography, vol.26, issue.1, pp.229-241, 2002. ,
Handbook of finite fields, ch. Computational linear algebra over finite fields, pp.520-535, 2013. ,
The complete analysis of a polynomial factorization algorithm over finite fields, Journal of Algorithms, vol.40, pp.37-81, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00073319
A kilobit hidden SNFS discrete logarithm computation, LNCS, vol.10210, pp.202-231, 2017. ,
DOI : 10.1007/978-3-319-56620-7_8
URL : https://hal.archives-ouvertes.fr/hal-01376934
, Discrete logarithms in GF, vol.2, 2013.
Discrete logarithms in GF(p) using the number field sieve, SIAM Journal on Discrete Mathematics, vol.6, issue.1, pp.124-138, 1993. ,
DOI : 10.1137/0406010
URL : http://www.ccrwest.org/gordon/log.pdf
Improved masking for tweakable blockciphers with applications to authenticated encryption, LNCS, vol.9665, pp.263-293, 2016. ,
DOI : 10.1007/978-3-662-49890-3_11
URL : http://eprint.iacr.org/2015/999.pdf
Breaking '128-bit secure' supersingular binary curves-(or how to solve discrete logarithms in F 2 4·1223 and F 2 12·367 ), CRYPTO 2014, Part II, vol.8617, pp.126-145, 2014. ,
DOI : 10.1007/978-3-662-44381-1_8
URL : https://infoscience.epfl.ch/record/215153/files/Neuchatel_short.pdf
Discrete logarithms in the Jacobian of a genus 2 supersingular curve over GF(2 367 ) (dl in GF(2 4404 )), Number Theory list, item 004665, 2014. ,
On the powers of 2, Cryptology ePrint Archive, 2014. ,
Computing discrete logarithms in F p 6, LNCS, vol.10719, pp.85-105, 2017. ,
Computing individual discrete logarithms faster in GF(p n ) with the NFSDL algorithm, LNCS, vol.9452, pp.149-173, 2015. ,
DOI : 10.1007/978-3-662-48797-6_7
URL : https://hal.archives-ouvertes.fr/hal-01157378
A new index calculus algorithm with complexity L(1/4 + o(1)) in small characteristic, Discrete logarithms in GF, vol.8282, pp.355-379, 2013. ,
DOI : 10.1007/978-3-662-43414-7_18
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-662-43414-7_18.pdf
Improvements to the general number field sieve for discrete logarithms in prime fields. A comparison with the Gaussian integer method, Algorithmic Number Theory, vol.2369, pp.953-967, 2002. ,
DOI : 10.1090/s0025-5718-02-01482-5
URL : https://hal.archives-ouvertes.fr/hal-01102016
The number field sieve in the medium prime case, CRYPTO 2006 (Cynthia Dwork, vol.4117, pp.326-344, 2006. ,
DOI : 10.1007/11818175_19
URL : https://hal.archives-ouvertes.fr/hal-01102034
Improving the polynomial time precomputation of frobenius representation discrete logarithm algorithms-simplified setting for small characteristic finite fields, ASIACRYPT 2014, Part I, LNCS, vol.8873, pp.45-61, 2014. ,
Discrete logarithm record in characteristic 3, GF(3 5·479 ) a 3796-bit field, Number Theory list, item 004745, 2014. ,
An upper bound on the number of monomials in determinants of sparse matrices with symbolic entries, Mathematica Pannonica, vol.8, pp.73-82, 1997. ,
Extended tower number field sieve: A new complexity for medium prime case, Cryptology ePrint Archive, 1027. ,
DOI : 10.1007/978-3-662-53018-4_20
URL : https://hal.archives-ouvertes.fr/hal-01281966
Extended tower number field sieve: A new complexity for the medium prime case, LNCS, vol.9814, pp.543-571, 2016. ,
Extended tower number field sieve with application to finite fields of arbitrary composite extension degree, LNCS, vol.10174, pp.388-408, 2017. ,
DOI : 10.1007/978-3-662-54365-8_16
Computation of a 768-bit prime field discrete logarithm, LNCS, vol.10210, pp.185-201, 2017. ,
DOI : 10.1007/978-3-319-56620-7_7
Computation of discrete logarithms in prime fields, Des. Codes Cryptography, vol.1, issue.1, pp.47-62, 1991. ,
, Factoring polynomials with rational coefficients, vol.261, pp.515-534, 1982.
DOI : 10.1007/bf01457454
URL : http://www.busim.ee.boun.edu.tr/~mihcak/teaching/ee684-spring07/proposed-project-papers/hard-problems/lattice-problems/lenstra.pdf
The XTR public key system, CRYPTO 2000 (Mihir Bellare, vol.1880, pp.1-19, 2000. ,
A hyperelliptic smoothness test, I, Philos. Trans. Roy. Soc. London Ser. A, vol.345, issue.3, pp.105-146, 1993. ,
Effective version of the number field sieve for discrete logarithms in the field GF(p k ), Trudy po Discretnoi Matematike, pp.121-151, 2006. ,
Discrete logarithms in finite fields and their cryptographic significance, LNCS, vol.209, pp.224-314, 1985. ,
DOI : 10.1007/3-540-39757-4_20
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-39757-4_20.pdf
Analysis and comparison of some integer factoring algorithms, Computational methods in number theory, part I, Mathematical Centre Tracts, vol.154, pp.89-139, 1982. ,
Another initial splitting in small characteristic finite fields, Personal communication, 2015. ,
A generalisation of the conjugation method for polynomial selection for the extended tower number field sieve algorithm, Cryptology ePrint Archive, A general polynomial selection method and new asymptotic complexities for the tower number field sieve algorithm, ASIACRYPT 2016, vol.10031, pp.409-423, 1993. ,
, Practical cryptography in high dimensional tori, EUROCRYPT 2005, vol.3494, pp.234-250, 2005.
Asymptotically optimal communication for torusbased cryptography, CRYPTO, vol.3152, pp.157-178, 2004. ,
Improvements on the individual logarithm step in extended tower number field sieve, Cryptology ePrint Archive, 2016. ,
, CS, vol.615, 20101.
, France E-mail address: aurore.guillevic@inria.fr URL
