New interface
Conference papers
Texture Rendering Strategies with a High Fidelity - Capacitive Visual-Haptic Friction Control Device
Abstract : Ultrasonic vibrations of a plate can modify the perception of the friction between a surface and a sliding finger. This principle, coupled with modern position sensing techniques, is able to reproduce textured materials. In this paper , an open loop control through model inversion of the friction force between the finger and the plate is presented. The device incorporating the control system is described, and two different reproduction strategies are formalized to address the reproduction of objects and textures. In the end, a psychophysical experiment evaluating the two control strategies is described.
Document type :
Conference papers
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/hal-01341981
Contributor : Eric Vezzoli Connect in order to contact the contributor
Submitted on : Friday, July 8, 2016 - 4:45:46 PM
Last modification on : Tuesday, December 6, 2022 - 12:42:12 PM
File
OpenLoopRev (1).pdf
Identifiers
Citation
Eric Vezzoli, Thomas Sednaoui, Michel Amberg, Frédéric Giraud, Betty Lemaire-Semail. Texture Rendering Strategies with a High Fidelity - Capacitive Visual-Haptic Friction Control Device. Haptics: Perception, Devices, Control, and Applications, Jul 2016, London, United Kingdom. ⟨10.1007/978-3-319-42321-0_23⟩. ⟨hal-01341981⟩
Share
Metrics
Record views
326
Files downloads
652
