Perception by the skin of electrically induced vibrations Electrovibration Modeling Analysis Surface haptics via electroadhesion: Expanding electrovibration with Johnsen and Rahbek, Haptics: Neuroscience, Devices, Modeling, and Applications 2015 IEEE World Haptics Conference (WHC), pp.277-278, 1953. ,
Squeeze film effect for the design of an ultrasonic tactile plate Role of Fingerprint Mechanics and non-Coulombic Friction in Ultrasonic Devices, IEEE Trans. Ultrason. Ferroelectr. Freq. Control, vol.546, issue.12, pp.2678-2688, 2007. ,
Discrimination of Virtual Square Gratings by Dynamic Touch on Friction Based Tactile Displays, " in symposium on Haptic interfaces for virtual environment and teleoperator systems Force can overcome object geometry in the perception of shape through active touch, Nature, vol.4128, issue.6845, pp.41-48, 2001. ,
A method for controlling tactile sensation of surface roughness using ultrasonic vibration Experimental evaluation of friction reduction in ultrasonic devices Role of Occlusion in Non-Coulombic Slip of the Finger Pad Closed-Loop Control for Squeeze Film Effect in Tactile Stimulator Mechanical behavior of the fingertip in the range of frequencies and displacements relevant to touch Physical and perceptual independence of ultrasonic vibration and electrovibration for friction modulation A High-Fidelity Surface-Haptic Device for Texture Rendering on Bare Finger STIMTAC: A Tactile Input Device with Programmable Friction The Spatial Spectrum of Tangential Skin Displacement Can Encode Tactual Texture Touch, IEEE International Conference on Robotics and Automation World Haptics Conference (WHC) Haptics: Neuroscience, Devices, Modeling, and Applications , M. Auvray and C. Duriez Proceedings of the 24th Annual ACM Symposium Adjunct on User Interface Software and Technology Handbook of Psychology Modeling and Synthesis of Tactile Texture with Spatial Spectrograms for Display on Variable Friction Surfaces IEEE -World Haptics Conf, pp.1134-1139, 1995. ,
