Abstract : The relationship between the physical parameters of pulsating vacuum sterilizer and the piping system states is analyzed based on cluster analysis and interpolation approximation algorithm. The cluster analysis is performed first, followed by the interpolation approximation of the cluster data. The algorithm provides a comprehensive sterilization efficacy evaluation, as well a feasible method to analyze the states of the system.
https://hal.inria.fr/hal-01342135 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, July 5, 2016 - 2:38:30 PM Last modification on : Wednesday, July 6, 2016 - 10:08:32 AM
Xicheng Fu, Mingcai Lin, Xingdong Ma. The Key Algorithm of the Sterilization Effectiveness of Pulsating Vacuum Sterilizer. 13th Conference on e-Business, e-Services and e-Society (I3E), Nov 2014, Sanya, China. pp.115-122, ⟨10.1007/978-3-662-45526-5_11⟩. ⟨hal-01342135⟩
