Channel estimation for non-ideal OFDM systems, IEEE Transactions on Communications, vol.58, issue.1, pp.146-156, 2010. ,
DOI : 10.1109/TCOMM.2010.01.070650
An algebraic receiver for full response CPM demodulation, 2006 International Telecommunications Symposium, 2006. ,
DOI : 10.1109/ITS.2006.4433304
URL : https://hal.archives-ouvertes.fr/inria-00086115
Multiple fundamental frequency estimation based on harmonicity and spectral smoothness, IEEE Transactions on Speech and Audio Processing, vol.11, issue.6, pp.804-816, 2003. ,
DOI : 10.1109/TSA.2003.815516
Estimation of Frequency and its Rate of Change for Applications in Power Systems, IEEE Transactions on Power Delivery, vol.19, issue.2, pp.472-480, 2004. ,
DOI : 10.1109/TPWRD.2003.822957
High-accuracy, wide-range frequency estimation methods for power system signals under non-sinusoidal conditions, IEEE Trans. Power Delivery, vol.20, issue.1, pp.366-374, 2005. ,
A Precise Calculation of Power System Frequency, IEEE Power Engineering Review, vol.21, issue.4, pp.361-366, 2001. ,
DOI : 10.1109/MPER.2001.4311328
Frequency tracking in power networks in the presence of harmonics, IEEE Transactions on Power Delivery, vol.8, issue.2, pp.480-486, 1993. ,
DOI : 10.1109/61.216849
A fast on-line frequency estimator of lightly damped vibrations in flexible structures, Journal of Sound and Vibration, vol.307, issue.1-2, pp.365-378, 2007. ,
DOI : 10.1016/j.jsv.2007.07.005
Adaptive Controller for Single-Link Flexible Manipulators Based on Algebraic Identification and Generalized Proportional Integral Control, IEEE Transactions on Systems, Man, and Cybernetics, Part B (Cybernetics), vol.39, issue.3, pp.735-751, 2009. ,
DOI : 10.1109/TSMCB.2008.2008905
Performance of higher harmonic control algorithms for helicopter vibration reduction, Journal of Guidance, Control, and Dynamics, vol.16, issue.4, pp.793-797, 1993. ,
DOI : 10.2514/3.21085
Adaptive algorithms for the rejection of sinusoidal disturbances with unknown frequency, Proc. 13th IFAC World Conf, 1996. ,
DOI : 10.1016/S0005-1098(97)00149-0
Unbalance compensation using generalized notch filters in the multivariable feedback of magnetic bearings, IEEE Transactions on Control Systems Technology, vol.4, issue.5, pp.580-586, 1996. ,
DOI : 10.1109/87.531924
An algebraic approach for humane posture estimation in the sagital plane using accelerometer noisy signal, Proc. 51st IEEE Conf. Decision Control, 2012. ,
Essai expérimental et analytique : sur les lois de la dilatabilité de fluidesélastiquesfluides´fluidesélastiques et sur celles de la force expansive de la vapeur de l'eau et de la vapeur de l'alcooì a différentes températures, Journal de l'´ ecole polytechnique, vol.1, issue.22, pp.24-76, 1795. ,
On the consistency of Prony's method and related algorithms, J. Comput. Graph. Statist, vol.1, pp.329-349, 1992. ,
A Modified Prony Algorithm for Exponential Function Fitting, SIAM Journal on Scientific Computing, vol.16, issue.1, pp.119-138, 1995. ,
DOI : 10.1137/0916008
Spectrum analysis—A modern perspective, Proceedings of the IEEE, vol.69, issue.11, pp.1380-1419, 1981. ,
DOI : 10.1109/PROC.1981.12184
List of references on spectral line analysis, Signal Processing, vol.31, issue.3, pp.329-340, 1993. ,
DOI : 10.1016/0165-1684(93)90090-W
Exact maximum likelihood parameter estimation of superimposed exponential signals in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.5, pp.1081-1089, 1986. ,
DOI : 10.1109/TASSP.1986.1164949
A generalized weighted linear predictor frequency estimation approach for a complex sinusoid, IEEE Transactions on Signal Processing, vol.54, issue.4, pp.1304-1315, 2006. ,
DOI : 10.1109/TSP.2005.863119
Adaptive Filter Theory, 1991. ,
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
DOI : 10.1109/29.32276
Conditions for stability of the extended Kalman filter and their application to the frequency tracking problem, Mathematics of Control, Signals and Systems, vol.38, issue.1, pp.1-26, 1995. ,
DOI : 10.1007/BF01212364
An extended Kalman filter frequency tracker for high-noise environments, IEEE Transactions on Signal Processing, vol.44, issue.2, pp.431-434, 1996. ,
DOI : 10.1109/78.485940
On the parametrization and design of an extended Kalman filter frequency tracker, IEEE Transactions on Automatic Control, vol.45, issue.9, pp.1718-1724, 2000. ,
DOI : 10.1109/9.880631
Analysis and performance evaluation of an adaptive notch filter, IEEE Transactions on Information Theory, vol.30, issue.2, pp.283-295, 1984. ,
DOI : 10.1109/TIT.1984.1056887
Adaptive notch filtering for the retrieval of sinusoids in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.4, pp.791-802, 1984. ,
DOI : 10.1109/TASSP.1984.1164398
Performance analysis of an adaptive notch filter with constrained poles and zeros, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.36, issue.6, pp.911-919, 1988. ,
DOI : 10.1109/29.1602
Unbiased estimation of a sinusoid in colored noise via adapted notch filters, Automatica, vol.33, issue.2, pp.209-215, 1997. ,
DOI : 10.1016/S0005-1098(96)00145-8
A new IIR adaptive notch filter, Signal Processing, vol.86, issue.7, pp.1648-1655, 2006. ,
DOI : 10.1016/j.sigpro.2005.09.010
Adaptive IIR Filtering in Signal Processing and Control, 1995. ,
Multi-sinusoidal signal estimation by an adaptive SOGI-filters bank, 15th IFAC Symp. on Sys. Ident, 2009. ,
DOI : 10.3182/20090706-3-FR-2004.00066
A globally convergent frequency estimator, IEEE Transactions on Automatic Control, vol.44, issue.4, pp.698-713, 1999. ,
DOI : 10.1109/9.754808
An Adaptive Notch Filter for Frequency Estimation of a Periodic Signal, IEEE Transactions on Automatic Control, vol.49, issue.2, pp.314-318, 2004. ,
DOI : 10.1109/TAC.2003.821414
Strong consistency of the contraction mapping method for frequency estimation, IEEE Transactions on Information Theory, vol.39, issue.3, pp.989-998, 1993. ,
DOI : 10.1109/18.256505
Fundamental frequency estimation based on the joint time-frequency analysis of harmonic spectral structure, IEEE Trans. Acoust., Speech, Signal Processing sep, vol.9, issue.6, pp.609-621, 2001. ,
Switched Algorithm for Frequency Estimation with Noise Rejection, IEEE Transactions on Automatic Control, vol.57, issue.9, pp.2400-2404, 2012. ,
DOI : 10.1109/TAC.2012.2186685
Hybrid Observer for Global Frequency Estimation of Saturated Signals, IEEE Transactions on Automatic Control, vol.54, issue.10, pp.2461-2464, 2009. ,
DOI : 10.1109/TAC.2009.2029395
A hybrid observer for frequency estimation of saturated multi-frequency signals. Decision and Control and European Control Conference (CDC-ECC), 50th IEEE Conference on, pp.2577-2582, 2011. ,
Global frequency estimation using adaptive identifiers, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1188-1193, 2002. ,
DOI : 10.1109/TAC.2002.800670
A property of the elementary symmetric functions on the frequencies of sinusoidal signals, Signal Processing, vol.89, issue.5, pp.765-777, 2009. ,
DOI : 10.1016/j.sigpro.2008.10.021
Parameter estimation via differential algebra and operational culculus. Research report URL https, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00138294
Parameter Identification of Sinusoids, IEEE Transactions on Automatic Control, vol.57, issue.2, pp.467-472, 2012. ,
DOI : 10.1109/TAC.2011.2164736
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Questioning some paradigms of signal processing via concrete examples, Algebraic Methods in Flatness, Signal Processing and State Estimation, pp.1-21, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00001059
Compression diff??rentielle de transitoires bruit??s, Comptes Rendus Mathematique, vol.339, issue.11, pp.821-826, 2004. ,
DOI : 10.1016/j.crma.2004.10.003
Critique du rapport signaì a bruit en communications numériques, ARIMA, vol.9, pp.419-429, 2008. ,
Identification of continuous-time models from sampled data. chapter Closed-loop parametric identification for continuous-time linear systems via new algebraic techniques, Advances in Industrial Control, pp.362-391, 2008. ,
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, pp.12-27, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
DOI : 10.1109/MED.2008.4602161
Algebraic change-point detection, Applicable Algebra in Engineering, Communication and Computing, vol.83, issue.2, pp.131-143, 2010. ,
DOI : 10.1007/s00200-010-0119-z
URL : https://hal.archives-ouvertes.fr/inria-00439226
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009. ,
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
Error analysis for a class of numerical differentiator: application to state observation, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, 2009. ,
DOI : 10.1109/CDC.2009.5400907
URL : https://hal.archives-ouvertes.fr/inria-00437129
Differentiation by integration with Jacobi polynomials, Journal of Computational and Applied Mathematics, vol.235, issue.9, pp.3015-3032, 2011. ,
DOI : 10.1016/j.cam.2010.12.023
URL : https://hal.archives-ouvertes.fr/inria-00550160
Error analysis of Jacobi derivative estimators for noisy signals, Numerical Algorithms, vol.21, issue.12, pp.439-467, 2011. ,
DOI : 10.1007/s11075-011-9447-8
URL : https://hal.archives-ouvertes.fr/inria-00573270
Convergence Rate of the Causal Jacobi Derivative Estimator, Lecture Notes in Computer Science, vol.50, issue.4, pp.439-467, 2011. ,
DOI : 10.1007/978-3-642-27413-8_28
URL : https://hal.archives-ouvertes.fr/inria-00599767
An algebraic frequency estimator for a biased and noisy sinusoidal signal, Signal Processing, vol.87, issue.6, pp.1188-1201, 2007. ,
DOI : 10.1016/j.sigpro.2006.10.006
