New interface
Journal articles
Solving bivariate systems using Rational Univariate Representations
Abstract : Given two coprime polynomials $P$ and $Q$ in $\Z[x,y]$ of degree bounded by $d$ and bitsize bounded by $\tau$, we address the problem of solving the system $\{P,Q\}$. We are interested in certified numerical approximations or, more precisely, isolating boxes of the solutions. We are also interested in computing, as intermediate symbolic objects, rational parameterizations of the solutions, and in particular Rational Univariate Representations (RURs), which can easily turn many queries on the system into queries on univariate polynomials. Such representations require the computation of a separating form for the system, that is a linear combination of the variables that takes different values when evaluated at the distinct solutions of the system. We present new algorithms for computing linear separating forms, RUR decompositions and isolating boxes of the solutions. We show that these three algorithms have worst-case bit complexity $\widetilde{O}_B(d^6+d^5\tau)$, where $\widetilde{O}$ refers to the complexity where polylogarithmic factors are omitted and $O_B$ refers to the bit complexity. We also present probabilistic Las Vegas variants of our two first algorithms, which have expected bit complexity $\widetilde{O}_B(d^5+d^4\tau)$. A key ingredient of our proofs of complexity is an amortized analysis of the triangular decomposition algorithm via subresultants, which is of independent interest.
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01342211
Contributor : Sylvain Lazard Connect in order to contact the contributor
Submitted on : Wednesday, July 6, 2016 - 7:45:13 PM
Last modification on : Tuesday, October 25, 2022 - 4:25:12 PM
JoC.pdf
Identifiers
Citation
Yacine Bouzidi, Sylvain Lazard, Guillaume Moroz, Marc Pouget, Fabrice Rouillier, et al.. Solving bivariate systems using Rational Univariate Representations. Journal of Complexity, 2016, 37, pp.34--75. ⟨10.1016/j.jco.2016.07.002⟩. ⟨hal-01342211v2⟩
Share
Metrics
Record views
346
Files downloads
272
