Surfacing Curve Networks with Normal Control
Recent surface acquisition technologies based on microsensors produce three-space tangential curve data which can be transformed into a network of space curves with surface normals. This paper addresses the problem of surfacing an arbitrary closed 3D curve network with given surface normals. Thanks to the normal vector input, the patch finding problem can be solved unambiguously and an initial piecewise smooth triangle mesh is computed. The input normals are propagated throughout the mesh. Together with the initial mesh, the propagated normals are used to compute mean curvature vectors. We then compute the final mesh as the solution of a new variational optimization method based on the mean curvature vectors. The intuition behind this original approach is to guide the standard Laplacian-based variational methods by the curvature information extracted from the input normals. The normal input increases shape fidelity and allows to achieve globally smooth and visually pleasing shapes.
smi2016.pdf (9.83 Mo)
Télécharger le fichier
fig_cylinders_compressed.pdf (93.81 Ko)
fig_funkylilium.pdf (307 Ko)
fig_gallery3_compressed.pdf (2.61 Mo)
fig_gamepad.pdf (1.98 Mo)
fig_horse_H_thin.pdf (203.78 Ko)
fig_morphorider.pdf (236.47 Ko)
