An Intuitive Framework for Realtime Freeform Modeling, Proc. SIGGRAPH), pp.630-634, 2004. ,
On Linear Variational Surface Deformation Methods, IEEE Trans. Vis. Comput. Graphics, vol.14, issue.1, pp.213-230, 2008. ,
Design-driven Quadrangulation of Closed 3D Curves, Proc. SIGGRAPH Asia), pp.1-17811, 2012. ,
A construction for visual c1 continuity of polynomial surface patches, Computer Graphics and Image Processing, vol.20, issue.7, pp.272-282, 1982. ,
3D Shape Measuring Sheet Utilizing Gravitational and Geomagnetic Fields, SICE Annual Conference, pp.915-920, 2008. ,
Mixed Finite Elements for Variational Surface Modeling, Computer Graphics ForumProc. SGP), vol.29, issue.5, pp.1565-1574, 2010. ,
Discrete Differential Geometry Operators for Triangulated 2-manifolds. In Visualization and mathematics III, pp.35-57, 2003. ,
Functional Optimization for Fair Surface Design, Computer Graphics (Proc. SIGGRAPH), vol.26, issue.2, pp.167-176, 1992. ,
Flow aligned surfacing of curve networks, Proc. SIGGRAPH), pp.1-12710, 2015. ,
DOI : 10.1145/1449715.1449740
Curve Reconstruction via a Ribbon of Sensors, 14th IEEE Int. Conf. on Electronics, Circuits and Systems, pp.407-410, 2007. ,
Triangle: Engineering a 2D Quality Mesh Generator and Delaunay Triangulator, Applied computational geometry towards geometric engineering, pp.203-222, 1996. ,
Flow-complex-based Shape Reconstruction from 3D Curves, ACM Trans. Graph, vol.33, issue.2, 2014. ,
Surfaces Reconstruction Via Inertial Sensors for Monitoring, 7th European Workshop on Structural Health Monitoring, 2014. ,
Curvatures of smooth and discrete surfaces, pp.175-188, 2008. ,
An Algorithm for Triangulating Multiple 3D Polygons, Proc. SGP), pp.157-166, 2013. ,
A General and Efficient Method for Finding Cycles in 3D Curve Networks, Proc. SIGGRAPH Asia) The Author(s) Eurographics Proceedings c 2016 The Eurographics Association, pp.1-180, 2013. ,
