The robust vehicle routing problem with time windows, Computers & Operations Research, vol.40, issue.3, pp.856-866, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00916976
A note on the bertsimas & sim algorithm for robust combinatorial optimization problems, vol.4, pp.349-360, 2013. ,
An algorithm for the resource constrained shortest path problem, Networks, vol.19, issue.4, pp.379-394, 1989. ,
Robust solutions of uncertain linear programs, Operations Research Letters, vol.25, pp.1-13, 1999. ,
Robust discrete optimization and network flows, Mathematical Programming, vol.98, pp.49-71, 2003. ,
The price of robustness, Operations Research, vol.52, pp.35-53, 2004. ,
Recoverable robust knapsacks: ?-scenarios, Network Optimization -5th International Conference, INOC 2011, pp.583-588, 2011. ,
Lagrangian relaxation and enumeration for solving constrained shortest-path problems, Networks, vol.52, issue.4, pp.256-270, 2008. ,
A reference point approach for the resource constrained shortest path problems, Transportation Science, vol.47, issue.2, pp.247-265, 2013. ,
A survey of resource constrained shortest path problems: Exact solution approaches, Networks, vol.62, issue.3, pp.183-200, 2013. ,
Improved preprocessing, labeling and scaling algorithms for the weight-constrained shortest path problem. Networks, vol.42, pp.135-153, 2003. ,
Two engineering applications of a constrained shortest-path model, European Journal of Operational Research, vol.103, issue.3, pp.426-438, 1997. ,
Optimization over integers with robustness in cost and few constraints, WAOA, pp.89-101, 2011. ,
An adaptive memory programming framework for the robust capacitated vehicle routing problem, Transportation Science, vol.50, issue.4, pp.1239-1260, 2016. ,
The robust capacitated vehicle routing problem under demand uncertainty, Operations Research, vol.61, issue.3, pp.677-693, 2013. ,
Shortest path with time constraints on movement and parking, vol.4, pp.241-253, 1974. ,
A robust approach to the chance-constrained knapsack problem, Oper. Res. Lett, vol.36, issue.5, pp.628-632, 2008. ,
Technical note -branch-and-priceand-cut approach to the robust network design problem without flow bifurcations, Operations Research, vol.60, issue.3, pp.604-610, 2012. ,
Robust vehicle routing problem with deadlines and travel time/demand uncertainty, Journal of the Operational Research Society, vol.63, issue.9, pp.1294-1306, 2012. ,
A short note on the robust combinatorial optimization problems with cardinality constrained uncertainty, vol.4, pp.373-378, 2014. ,
On an exact method for the constrained shortest path problem, Computers & Operations Research, vol.40, pp.278-284, 2013. ,
Robust optimization for airline scheduling and vehicle routing, 2014. ,
The robust crew pairing problem: model and solution methodology, Journal of Global Optimization, vol.62, issue.1, pp.29-54, 2015. ,
Models and algorithms for the robust resource constrained shortest path problem, 2018. ,
Resource constraint shortest paths, 8 th Ann Eur Symp on Algorithms (ESA2000), vol.1879, pp.326-337, 2000. ,
Constrained shortest path with uncertain transit times, Journal of Global Optimization, vol.63, issue.1, pp.149-163, 2015. ,
DOI : 10.1007/s10898-015-0280-9
Exact solution of the robust knapsack problem, Computers & OR, vol.40, issue.11, pp.2625-2631, 2013. ,
Robust vehicle routing, TUTORIALS in Operations Research, pp.153-178, 2010. ,
Branch-and-cut-andprice for the robust capacitated vehicle routing problem with knapsack uncertainty, 2018. ,
Robust constrained shortest path problems under budgeted uncertainty, Networks, vol.66, issue.2, pp.98-111, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01229790
Robust combinatorial optimization with variable budgeted uncertainty, vol.4, pp.75-92, 2013. ,
DOI : 10.1007/s10288-012-0217-9
URL : https://hal.archives-ouvertes.fr/hal-00916975
Robust combinatorial optimization with variable cost uncertainty, European Journal of Operational Research, vol.237, issue.3, pp.836-845, 2014. ,
DOI : 10.1016/j.ejor.2014.02.060
URL : https://hal.archives-ouvertes.fr/hal-01099569
Robust combinatorial optimization with knapsack uncertainty, Discrete Optimization, vol.27, pp.88-102, 2018. ,
DOI : 10.1016/j.disopt.2017.09.004
URL : https://hal.archives-ouvertes.fr/hal-01444717
A survey on dynamic and stochastic vehicle routing problems, International Journal of Production Research, vol.54, issue.1, pp.215-231, 2016. ,
DOI : 10.1080/00207543.2015.1043403
URL : https://hal.archives-ouvertes.fr/hal-01224562
An improved solution algorithm for the constrained shortest path problem, Transport Res BMeth, vol.41, issue.7, pp.756-771, 2007. ,
A dynamic programming approach for a class of robust optimization problems, SIAM Journal on Optimization, vol.3, pp.1799-1823, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01348688
An enhanced k-sp algorithm with pruning strategies to solve the constrained shortest path problem, Applied Mathematics and Computation, vol.265, pp.602-618, 2015. ,
A robust optimization approach for the capacitated vehicle routing, IIE Transactions, vol.40, issue.5, pp.509-523, 2008. ,
DOI : 10.1080/07408170701745378
The constrained shortest path problem with stochastic correlated link travel times, European Journal of Operational Research, vol.255, issue.1, pp.43-57, 2016. ,
Primal-dual algorithms for computing weight-constrained shortest paths and weight-constrained minimum spanning trees, Performance, Computing, and Communications Conference, pp.271-277, 2000. ,
Optimal risk path algorithms. Applied Optimization, vol.66, pp.273-296, 2002. ,
DOI : 10.1007/0-306-47536-7_13
