Link-layer Security in TSCH Networks: Effect on Slot Duration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on emerging telecommunications technologies Année : 2016
The IEEE802.15.4e-2012 standard is widely used in multi-hop wireless Industrial Internet of Things (IIoT) applications. In the Time-Slotted Channel Hopping (TSCH) mode, nodes are synchronized, and time is cut into timeslots. A schedule orchestrates all communications, resulting in high reliability and low power operations. A timeslot must be long enough for a node to send a data frame to its neighbor, and for that neighbor to send back an acknowledgment. Shorter timeslots enable higher bandwidth and lower latency, yet the minimal timeslot duration is limited by how long link-layer security operations take. We evaluate the overhead of link-layer security in TSCH networks in terms of minimal timeslot length, memory footprint, and energy consumption. We implement full link-layer security on a range of hardware platforms, exploring di erent hardware/software implementation strategies. Through an extensive measurement campaign, we quantify the advantage of hardware accelerations for link-layer security, and show how the minimal duration of a timeslot varies between 9 ms and 88 ms for the most common con guration, depending on hardware support. Furthermore, we also highlighted the impact that the timeslot duration has on both high-level application design and energy consumption.
sec-overhead.pdf (482.05 Ko) Télécharger le fichier
hal-01342664 , version 1 (20-12-2016)
Savio Sciancalepore, Malisa Vucinic, Giuseppe Piro, Gennaro Boggia, Thomas Watteyne. Link-layer Security in TSCH Networks: Effect on Slot Duration. Transactions on emerging telecommunications technologies, 2016, ⟨10.1002/ett.3089⟩. ⟨hal-01342664⟩
528 Consultations
564 Téléchargements
