Energy Harvesting Wireless Sensor Networks: From Characterization to Duty Cycle Dimensioning
Energy harvesting capabilities are challenging our understanding of wireless sensor networks by adding recharging capacity to sensor nodes. This has a significant impact on the communication paradigm, as networking mechanisms can benefit from these potentially infinite renewable energy sources. In this work, we study the consequences of implementing photovoltaic energy harvesting on the duty cycle of a wireless sensor node, in both outdoor and indoor scenarios. We show that for the static duty cycle approach in outdoor scenarios, very high duty cycles, in the order of tens of percents, are achieved. This further eliminates the need for additional energy conservation schemes. In the indoor case, our analysis shows that the dynamic duty cycle approach based solely on the battery residual energy does not necessarily achieve better results than the static approach. We identify the main reasons behind this behavior, and test new design considerations by adding information on the battery level variation to the duty cycle computation. We demonstrate that this approach always outperforms static solutions when perfect knowledge of the harvestable energy is assumed, as well as in realistic deployments, where this information is not available.
