Study and Characterization of Power Distribution Network Reconfiguration, 2006 IEEE/PES Transmission & Distribution Conference and Exposition: Latin America, pp.1-6, 2006. ,
DOI : 10.1109/TDCLA.2006.311517
Minimum Loss Network Reconfiguration Using Mixed-Integer Convex Programming, IEEE Transactions on Power Systems, vol.27, issue.2, pp.1106-1115, 2012. ,
DOI : 10.1109/TPWRS.2011.2180406
Long-term multi-objective distribution network planning by DG allocation and feeders??? reconfiguration, Electric Power Systems Research, vol.105, pp.95-102, 2013. ,
DOI : 10.1016/j.epsr.2013.07.016
Reconfiguration of Power Distribution Systems Considering Reliability and Power Loss, IEEE Transactions on Power Delivery, vol.27, issue.2, pp.918-926, 2012. ,
DOI : 10.1109/TPWRD.2011.2179950
Study of Reconfiguration for the Distribution System With Distributed Generators, IEEE Transactions on Power Delivery, vol.25, issue.3, pp.1678-1684, 2010. ,
DOI : 10.1109/TPWRD.2010.2046339
Multi-Objective Stochastic Distribution Feeder Reconfiguration in Systems With Wind Power Generators and Fuel Cells Using the Point Estimate Method, IEEE Transactions on Power Systems, vol.28, issue.2, pp.1483-1492, 2013. ,
DOI : 10.1109/TPWRS.2012.2218261
A mixed-integer LP model for the reconfiguration of radial electric distribution systems considering distributed generation, Electric Power Systems Research, vol.97, pp.51-60, 2013. ,
DOI : 10.1016/j.epsr.2012.12.005
Effective implementation of the ??-constraint method in Multi-Objective Mathematical Programming problems, Applied Mathematics and Computation, vol.213, issue.2, pp.455-465, 2009. ,
DOI : 10.1016/j.amc.2009.03.037
An improved version of the augmented ??-constraint method (AUGMECON2) for finding the exact pareto set in multi-objective integer programming problems, Applied Mathematics and Computation, vol.219, issue.18, pp.9652-9669, 2013. ,
DOI : 10.1016/j.amc.2013.03.002
Multiobjective Programming and Planning, 1978. ,
Caracterização das redes de transporte e distribuição da Região Autónoma dos Açores, " S. Miguel, 2014. flow limit of branch ' [0`]; ,DEF -max. power that substation of node ) can provide ,
