Distributed energy resources and benefits to the environment, Renewable and Sustainable Energy Reviews, vol.14, issue.2, pp.724-734, 2010. ,
DOI : 10.1016/j.rser.2009.10.025
Overview of Control and Grid Synchronization for Distributed Power Generation Systems, IEEE Transactions on Industrial Electronics, vol.53, issue.5, pp.1398-1409, 2006. ,
DOI : 10.1109/TIE.2006.881997
Stability of photovoltaic and wind turbine grid-connected inverters for a large set of grid impedance values, Hoseini et al, pp.263-272, 2006. ,
DOI : 10.1109/TPEL.2005.861185
Adaptive Grid-Voltage Sensorless Control Scheme for Inverter-Based Distributed Generation, IEEE Transactions on Energy Conversion, vol.24, issue.3, pp.683-694, 2009. ,
DOI : 10.1109/TEC.2008.2001448
An adaptive controller for inverter-interfaced DGs connected to grids with a wide range of unknown impedances. Energy Conversion Congress and Exposition (ECCE), pp.2871-2877, 2010. ,
Impedance-Based Stability Criterion for Grid-Connected Inverters, IEEE Transactions on Power Electronics, vol.26, issue.11, pp.3075-3078, 2011. ,
DOI : 10.1109/TPEL.2011.2136439
A Robust Control Scheme for Grid-Connected Voltage-Source Inverters, IEEE Transactions on Industrial Electronics, vol.58, issue.1, pp.202-212, 2011. ,
DOI : 10.1109/TIE.2010.2045998
Fractional-order systems and PI?Dµ controllers, IEEE Trans Autom Control, vol.41, issue.1, pp.208-213, 1999. ,
Fractional robust system control, 2005. ,
A General Formulation and Solution Scheme for Fractional Optimal Control Problems, Nonlinear Dynamics, vol.29, issue.1-4, pp.323-337, 2006. ,
DOI : 10.1007/s11071-004-3764-6
Optimality conditions and a solution scheme for fractional optimal control problems, Structural and Multidisciplinary Optimization, vol.124, issue.3, pp.571-581, 2009. ,
DOI : 10.1007/s00158-008-0307-7
Modern sliding mode control theory: new perspectives and applications, 2008. ,
DOI : 10.1007/978-3-540-79016-7
Advances in variable structure and sliding mode control, 2006. ,
DOI : 10.1007/11612735
Boolean-based fractional order SMC for switching systems: application to a DC-DC buck converter, Signal Image and Video Processing, pp.445-451, 2012. ,
DOI : 10.1007/s11760-012-0318-0
Sliding mode control approaches to the robust regulation of linear multivariable fractional-order dynamics, International Journal of Robust and Nonlinear Control, vol.40, issue.11, pp.2045-2056, 2010. ,
DOI : 10.1002/rnc.1565
Fractional order sliding mode control with reaching law approach, Turk J Electr Eng Comput Sci, vol.18, issue.5, pp.731-747, 2010. ,
