A. Dineva, R. Annamária, . Várkonyi-kóczy, and K. József, Tar Selection of Large-Scale 3D Point Cloud Data using Gesture Recognition, p.188
C. Classifier-for-service-robots, .. Ferreira, F. Miranda, P. Sousa, and .. , José Barata, and João Pimentão Distributed RSS-Based Localization in Wireless Sensor Networks with Node Selection Mechanism 204 Slavisa Tomic, Marko Beko, Rui Dinis, Goran Dimic, and Milan Tuba Signal Processing in Medicine Continuous Speech Classification Systems for Voice Pathologies Identification, p.217
H. Cordeiro, C. Meneses, and .. , and José Fonseca 3D Human Scanning Solution for Medical Measurements, p.225
M. Viktor-zoltan-jonas and B. Kozlovszky, Molnar High Resolution Digital Tissue Image Processing using Texture Image Databases, p.239
G. Kiss, O. Eszter-cseri, and Á. , István Imre Bándi, Levente Kovács, and Miklos Kozlovszky Smart Monitoring Systems Georeferenced Dynamic Event Handling, p.251
S. Onofre, J. P. Pimentão, P. Sousa, and .. , Energy: Improvement Analysis of Causes and Effects of Harmonic Distortion in Electric Power Systems and Solutions to Comply with, International Standards Regarding Power Quality, p.357
M. Ruiz-cortés, M. Isabel-milanés-montero-aggregator, and .. , Fermín Barrero-González, and Enrique Romero-Cadaval Risk Analysis and Behavior of Electricity Portfolio, p.365
E. Eusébio, J. De-sousa, M. Improvement, and .. , 374 Nuno Amaro, Luís Casimiro, João Murta Pina, João Martins, and José Maria Ceballos Energy: Decision Support Offering Strategies of Wind Power Producers in a Day-Ahead Electricity Market, 385 R. Laia, H.M.I. Pousinho, R. Melício, V.M.F. Mendes, and M. Collares-Pereira New Multi-objective Decision Support Methodology to Solve Problems of Reconfiguration in the Electric Distribution Systems, p.395
F. Sérgio, N. G. Santos, and J. P. Paterakis, Catalão Cloud-Based Decision Support Ecosystem for Renewable Energy Providers, p.405
I. Andreea-sta-?nescu, A. Stefan, F. Gheorghe-filip-energy-superconducting-fault-current-limiter, .. Melício, V. M. Mendes et al., 415 Nuno Vilhena Anabela Gonçalves Pronto, and Alfredo Álvarez Simulation of a-Si PV System Linked to the Grid by DC Boost and Three-Level Inverter Under Cloud Scope Collares-Pereira Modeling Reserve Ancillary Service as Virtual Energy Carrier in Multi-Energy Systems Catalão Simulation of Offshore Wind System with Three-Level Converters: HVDC Power Transmission in Cloud Scope, 440 M. Seixas, R. Melício, V.M.F. Mendes, M. Collares-Pereira, and M.P. dos Santos Energy: Power Conversion I Disc Motor with Rotor Made of Aluminium or Polycrystalline High Temperature Superconductor, p.451
D. Inácio, J. M. Pina, M. Ventim-neves, and A. , Álvarez Investigation of the Tesla Transformer as a Device for One-Wire Power and Signaling and as a Device for Power and Signaling Through the Ground 459 Kaloyan Mihaylov, Rui Neves-Medeiros, Rumen Arnaudov, and Stanimir Valtchev Experimental Magnetic Field Mapping of a Polycrystalline Superconducting YBCO Disc for an Axial Flux Motor, p.467
D. Inácio, J. M. Pina, J. Maria-ceballos, and .. , Mário Ventim Neves, and Alfredo Álvarez Energy: Power Conversion II Analysis of a Multi-Ratio Switched Capacitor DC-DC Converter for a Supercapacitor Power Supply, p.477
A. Piezoelectric-device, P. Measurement, M. Alves, J. M. Dias, J. M. Pereira et al., Fonseca Design of High Voltage Full-Bridge Inverter Using Marx Derived Switches, F. Pinto, and Duarte Sousa Stable Integration of Power Electronics-Based DG Links to the Utility Grid with Interfacing Impedance Uncertainties 502 S. Kazem Hoseini, Edris Pouresmaeil, Jafar Adabi, and João P.S. Catalão Erratum to: Selection of Large-Scale 3D Point Cloud Data Using Gesture Recognition
