The k-simultaneous consensus problem, Distributed Computing, vol.29, issue.5, pp.185-195, 2010. ,
DOI : 10.1007/s00446-009-0090-8
URL : https://hal.archives-ouvertes.fr/inria-00354248
Local and global properties in networks of processors (Extended Abstract), Proceedings of the twelfth annual ACM symposium on Theory of computing , STOC '80, pp.82-93, 1980. ,
DOI : 10.1145/800141.804655
A modular approach to shared-memory consensus, with applications to the probabilistic-write model, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.179-188, 2012. ,
DOI : 10.1145/1835698.1835802
Tight Bounds for Adopt-Commit Objects, Theory of Computing Systems, vol.38, issue.4, pp.451-474, 2014. ,
DOI : 10.1007/s00224-013-9448-1
Adapting to Point Contention with Long-Lived Safe Agreement, Proceedings of the 13th International Colloquium on Structural Information and Communication Complexity(SIROCCO ), pp.10-23, 2006. ,
DOI : 10.1007/11780823_2
Computing in Totally Anonymous Asynchronous Shared Memory Systems, Information and Computation, vol.173, issue.2, pp.162-183, 2002. ,
DOI : 10.1006/inco.2001.3119
Better computing on the anonymous ring, Journal of Algorithms, vol.12, issue.2, pp.204-238, 1991. ,
DOI : 10.1016/0196-6774(91)90002-G
Computing on an anonymous ring, Journal of the ACM, vol.35, issue.4, pp.845-875, 1988. ,
DOI : 10.1145/48014.48247
Consensus in Anonymous Distributed Systems: Is There a Weakest Failure Detector?, 2010 24th IEEE International Conference on Advanced Information Networking and Applications, pp.206-213, 2010. ,
DOI : 10.1109/AINA.2010.19
URL : https://hal.archives-ouvertes.fr/inria-00426674
Anonymous asynchronous systems: the case of failure detectors, Distributed Computing, vol.7, issue.1, pp.141-158, 2013. ,
DOI : 10.1007/s00446-012-0169-5
URL : https://hal.archives-ouvertes.fr/inria-00452799
-resilient asynchronous computations, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.91-100, 1993. ,
DOI : 10.1145/167088.167119
URL : https://hal.archives-ouvertes.fr/hal-00896459
The BG distributed simulation algorithm, Distributed Computing, vol.14, issue.3, pp.127-146, 2001. ,
DOI : 10.1007/PL00008933
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
Unreliable failure detectors for reliable distributed systems, J. ACM, vol.43, issue.2, pp.225-267, 1996. ,
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
A survey of anonymous communication channels, 2008. ,
Two consensus algorithms with atomic registers and failure detector omega, Proceedings of the 10th International Conference on Distributed Computing and Networking, ICDCN '09, pp.251-262, 2009. ,
Wait-freedom with advice, Distributed Computing, vol.22, issue.5???6, pp.3-19, 2015. ,
DOI : 10.1007/s00446-014-0231-6
URL : https://hal.archives-ouvertes.fr/hal-01269956
Tight failure detection bounds on atomic object implementations, J. ACM, vol.57, issue.4, 2010. ,
On the space complexity of randomized synchronization, Journal of the ACM, vol.45, issue.5, pp.843-862, 1998. ,
DOI : 10.1145/290179.290183
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
The failure detector abstraction, ACM Comput. Surv, vol.43, issue.2, p.9, 2011. ,
Round-by-round fault detectors (extended abstract), Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.143-152, 1998. ,
DOI : 10.1145/277697.277724
The extended BG-simulation and the characterization of t-resiliency, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.85-92, 2009. ,
DOI : 10.1145/1536414.1536428
On set consensus numbers. Distributed Computing, pp.149-163, 2011. ,
The Weakest Failure Detectors to Solve Quittable Consensus and Nonblocking Atomic Commit, SIAM Journal on Computing, vol.41, issue.6, pp.1343-1379, 2012. ,
DOI : 10.1137/070698877
Anonymous and fault-tolerant shared-memory computing, Distributed Computing, pp.165-177, 2007. ,
DOI : 10.1007/s00446-007-0042-0
Visiting Gafni???s Reduction Land: From the BG Simulation to the Extended BG Simulation, Proceedings of the 11th International Symposium on Stabilization , Safety, and Security of Distributed Systems (SSS), pp.369-383, 2009. ,
DOI : 10.1007/978-3-642-05118-0_26
Memory requirements for agreement among unreliable asynchronous processes, Advances in Computing Research, pp.163-183, 1987. ,
The Combined Power of Conditions and Information on Failures to Solve Asynchronous Set Agreement, SIAM Journal on Computing, vol.38, issue.4, pp.1574-1601, 2008. ,
DOI : 10.1137/050645580
Computing on an anonymous network, Proceedings of the seventh annual ACM Symposium on Principles of distributed computing , PODC '88, pp.69-89, 1996. ,
DOI : 10.1145/62546.62568
Computing on an anonymous network, Proceedings of the seventh annual ACM Symposium on Principles of distributed computing , PODC '88, pp.90-96, 1996. ,
Anti-Omega: the weakest failure detector for set agreement, Distributed Computing, pp.335-348, 2010. ,
