Forward Error Correction (FEC) Framework version 2
Vincent Roca 1 Ali Begen 2
1 PRIVATICS - Privacy Models, Architectures and Tools for the Information Society
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : This document describes a framework for using Forward Error Correction (FEC) codes with applications in public and private IP networks to provide protection against packet loss. The framework supports applying FEC to arbitrary packet flows over unreliable transport and is primarily intended for real-time, or streaming, media. This framework can be used to define Content Delivery Protocols that provide FEC for streaming media delivery or other packet flows. Content Delivery Protocols defined using this framework can support any FEC scheme (and associated FEC codes) that is compliant with various requirements defined in this document. Thus, Content Delivery Protocols can be defined that are not specific to a particular FEC scheme, and FEC schemes can be defined that are not specific to a particular Content Delivery Protocol. The first version of FECFRAME defined in [RFC6363] was restricted to block FEC codes. The FECFRAME version 2 defined in this document adds the possibility to use Convolutional FEC Codes in addition to Block FEC Codes.
Type de document :
Autre publication
Working document of the TSVWG (Transport Area Working Group) group of IETF (Internet Engineering .. 2016
Liste complète des métadonnées
Littérature citée [22 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01345125
Contributeur : Vincent Roca <>
Soumis le : lundi 19 décembre 2016 - 14:21:05
Dernière modification le : mercredi 28 février 2018 - 15:20:28
Fichier
draft-roca-tsvwg-fecframev2-02...
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01345125, version 2
Citation
Vincent Roca, Ali Begen. Forward Error Correction (FEC) Framework version 2. Working document of the TSVWG (Transport Area Working Group) group of IETF (Internet Engineering .. 2016. 〈hal-01345125v2〉
Métriques
Consultations de la notice
91
Téléchargements de fichiers
17
