Key words for use in RFCs to Indicate Requirement Levels, 1997. ,
DOI : 10.17487/rfc2119
An Architecture for Describing Simple Network Management Protocol (SNMP) Management Frameworks, 2002. ,
DOI : 10.17487/rfc3411
Forward Error Correction (FEC) Building Block, RFC, vol.5052, 2007. ,
DOI : 10.17487/rfc5052
Guidelines for Writing an IANA Considerations Section in RFCs, BCP, vol.26, issue.5226, 2008. ,
DOI : 10.17487/rfc5226
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.180.9238
Augmented BNF for Syntax Specifications: ABNF, STD, vol.68, issue.5234, 2008. ,
The Syslog Protocol, RFC, vol.5424, 2009. ,
DOI : 10.17487/rfc5424
Forward Error Correction (FEC) Framework, RFC, vol.6363, 2011. ,
DOI : 10.17487/rfc6363
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.3307
Forward Error Correction (FEC) Streaming Framework, Work in Progress, 2005. ,
RObust Header Compression (ROHC): Framework and four profiles, 2001. ,
RTP: A Transport Protocol for Real-Time Applications, 2003. ,
DOI : 10.17487/rfc3550
The Secure Real-time Transport Protocol (SRTP), RFC, vol.3711, 2004. ,
DOI : 10.17487/rfc3711
The Use of Timed Efficient Stream Loss-Tolerant Authentication (TESLA) in the Secure Real-time Transport Protocol (SRTP), RFC, vol.4383, 2006. ,
DOI : 10.17487/rfc4383
SDP: Session Description Protocol, RFC, vol.4566, 2006. ,
DOI : 10.17487/rfc4566
Mapping Simple Network Management Protocol (SNMP) Notifications to SYSLOG Messages, RFC, vol.5675, 2009. ,
DOI : 10.17487/rfc5675
Definitions of Managed Objects for Mapping SYSLOG Messages to Simple Network Management Protocol (SNMP) Notifications, RFC, vol.5676, 2009. ,
DOI : 10.17487/rfc5676
Post-Repair Loss RLE Report Block Type for RTP Control Protocol (RTCP) Extended Reports (XRs), 2010. ,
DOI : 10.17487/rfc5725
NACK-Oriented Reliable Multicast (NORM) Transport Protocol, RFC, vol.5740, 2009. ,
DOI : 10.17487/rfc5740
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.697.7856
Asynchronous Layered Coding (ALC) Protocol Instantiation, RFC, vol.5775, 2010. ,
DOI : 10.17487/rfc5775
Session Description Protocol Elements for FEC Framework, RFC, vol.6364, 2011. ,
DOI : 10.17487/rfc6364
Raptor Forward Error Correction (FEC) Schemes for FECFRAME, RFC, vol.6681, 2012. ,
DOI : 10.17487/rfc6681
Simple Low-Density Parity Check (LDPC) Staircase Forward Error Correction (FEC) Scheme for FECFRAME, RFC, vol.6816, 2012. ,
DOI : 10.17487/rfc6816
URL : https://hal.archives-ouvertes.fr/hal-00781906
Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME, RFC, vol.6865, 2013. ,
DOI : 10.17487/rfc6865
URL : https://hal.archives-ouvertes.fr/hal-00799727
