, Operations and Management Considerations This FECFRAME extension does not add any new Operations and Management Consideration
, IANA Considerations No IANA actions are required for this document
, A FEC Scheme for use with this FEC Framework is identified via its FEC Encoding ID. It is subject to IANA registration in the "FEC Framework (FECFRAME) FEC Encoding IDs" registry. All the rules of
, Acknowledgments The authors would like to thank Christer Holmberg, David Black, Gorry Fairhurst, and Emmanuel Lochin for their valuable feedbacks on this document
Key words for use in RFCs to Indicate Requirement Levels, BCP, vol.14, p.2119, 1997. ,
DOI : 10.17487/rfc2119
Forward Error Correction (FEC) Framework, 2011. ,
DOI : 10.17487/rfc6363
URL : https://www.rfc-editor.org/rfc/pdfrfc/rfc6363.txt.pdf
Ambiguity of Uppercase vs Lowercase in RFC 2119 Key Words, BCP, vol.14, 2017. ,
, Multimedia Broadcast/Multicast Service (MBMS
, 3GPP TS 26, vol.346, 2009.
, Internet-Draft FEC Framework Extension, 2018.
Forward Error Correction (FEC) Building Block, vol.5052, 2007. ,
Session Description Protocol Elements for the Forward Error Correction (FEC) Framework, 2011. ,
Raptor Forward Error Correction (FEC) Schemes for FECFRAME, 2012. ,
Simple Low-Density Parity Check (LDPC) Staircase Forward Error Correction (FEC) Scheme for FECFRAME, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00781906
Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME, RFC, vol.6865, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00799727
Taxonomy of Coding Techniques for Efficient Network Communications, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-00998506
Sliding Window Random Linear Code (RLC) Forward Erasure Correction (FEC) Scheme for FECFRAME, Transport Area Working Group, 2018. ,
