Chaotic Chebyshev Polynomials Based Remote User Authentication Scheme in Client-Server Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Toan-Thinh Truong
  • Fonction : Auteur
  • PersonId : 986188
Minh-Triet Tran
  • Fonction : Auteur
  • PersonId : 986189
Isao Echizen
  • Fonction : Auteur
  • PersonId : 986191
Perfect forward secrecy is considered as the most important standard to evaluate a strong authentication scheme. There are many results researched to achieve this property without using hard problems. Recently, the result of Chang et al has some advances such as, the correctness of schemes mutual authentication and session key agreement demonstrated in BAN-logic or the overheads reduction of system implementation. However, in this paper, we prove that their scheme is still vulnerable to impersonation attacks and session key leakage. To overcome those limitations and be practical, we use different notion to propose time efficient scheme conducted in experiment. Our proposed method can be applied for remote user authentication in various scenarios, including systems with user authentication using mobile or wearable devices.
337885_1_En_32_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01345140 , version 1 (13-07-2016)
Paternité
Toan-Thinh Truong, Minh-Triet Tran, Anh-Duc Duong, Isao Echizen. Chaotic Chebyshev Polynomials Based Remote User Authentication Scheme in Client-Server Environment. 30th IFIP International Information Security Conference (SEC), May 2015, Hamburg, Germany. pp.479-494, ⟨10.1007/978-3-319-18467-8_32⟩. ⟨hal-01345140⟩
75 Consultations
140 Téléchargements
