Abstract : Given a nonsingular $n \times n$ matrix of univariate polynomials over a field
$\mathbb{K}$, we give fast and deterministic algorithms to compute its
determinant and its Hermite normal form. Our algorithms use
$\widetilde{\mathcal{O}}(n^\omega \lceil s \rceil)$ operations in
$\mathbb{K}$, where $s$ is bounded from above by both the average of the
degrees of the rows and that of the columns of the matrix and $\omega$ is the
exponent of matrix multiplication. The soft-$O$ notation indicates that
logarithmic factors in the big-$O$ are omitted while the ceiling function
indicates that the cost is $\widetilde{\mathcal{O}}(n^\omega)$ when $s =
o(1)$. Our algorithms are based on a fast and deterministic triangularization
method for computing the diagonal entries of the Hermite form of a nonsingular
matrix.
