Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, pp.21-28, 1962. ,
DOI : 10.1109/TIT.1962.1057683
Near Shannon limit performance of low density parity check codes, Electronics Letters, vol.33, issue.6, pp.457-458, 1997. ,
DOI : 10.1049/el:19970362
A recursive approach to low complexity codes, IEEE Transactions on Information Theory, vol.27, issue.5, pp.533-547, 1981. ,
DOI : 10.1109/TIT.1981.1056404
On generalized low-density parity-check codes based on Hamming component codes, IEEE Communications Letters, vol.3, issue.8, pp.248-250, 1999. ,
DOI : 10.1109/4234.781010
Generalized Low-Density Parity-Check Codes Based on Hadamard Constraints, IEEE Transactions on Information Theory, vol.53, issue.3, pp.1058-1079, 2007. ,
DOI : 10.1109/TIT.2006.890694
A hybrid coding scheme for the Gilbert-Elliott channel, IEEE Transactions on Communications, vol.54, issue.10, pp.1787-1796, 2006. ,
DOI : 10.1109/TCOMM.2006.881365
Generalized LDPC codes with Reed-Solomon and BCH codes as component codes for binary channels, GLOBECOM '05. IEEE Global Telecommunications Conference, 2005., 2005. ,
DOI : 10.1109/GLOCOM.2005.1577850
Generalized low-density parity-check codes for optical communication systems, Journal of Lightwave Technology, vol.23, issue.5, pp.1939-1946, 2005. ,
DOI : 10.1109/JLT.2005.846892
Doubly Generalized LDPC Codes, 2006 IEEE International Symposium on Information Theory, pp.669-673, 2006. ,
DOI : 10.1109/ISIT.2006.261869
URL : https://hal.archives-ouvertes.fr/hal-00865899
Analysis of Doubly-Generalized LDPC Codes with Random Component Codes for the Binary Erasure Channel, Allerton Conference on Communications, Control and Computing, 2006. ,
Low density parity check (ldpc) staircase and triangle forward error correction (fec) schemes, IETF Request for Comments, 2008. ,
DOI : 10.17487/rfc5170
URL : https://hal.archives-ouvertes.fr/inria-00000147
Low-rate coding using incremental redundancy for GLDPCcodes, IEEE Int. Workshop on Satellite and Space Communications, 2008. ,
Design of small rate, close to ideal, GLDPC-staircase AL-FEC codes for the erasure channel, 2012 IEEE Global Communications Conference (GLOBECOM), 2012. ,
DOI : 10.1109/GLOCOM.2012.6503433
URL : https://hal.archives-ouvertes.fr/hal-00736071
Good coupling between LDPC-staircase and Reed-Solomon for the design of GLDPC codes for the erasure channel, 2013 IEEE Wireless Communications and Networking Conference (WCNC), 2013. ,
DOI : 10.1109/WCNC.2013.6554790
URL : https://hal.archives-ouvertes.fr/hal-00781921
Complexity comparison of the use of Vandermonde versus Hankel matrices to build systematic MDS Reed-Solomon codes, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012. ,
DOI : 10.1109/SPAWC.2012.6292924
URL : https://hal.archives-ouvertes.fr/hal-00719314
Generalized IRA Erasure Correcting Codes for Hybrid Iterative/Maximum Likelihood Decoding, IEEE Communications Letters, vol.12, issue.6, pp.450-452, 2008. ,
DOI : 10.1109/LCOMM.2008.080221
Optimizing the error recovery capabilities of LDPC-staircase codes featuring a Gaussian elimination decoding scheme, 2008 10th International Workshop on Signal Processing for Space Communications, 2008. ,
DOI : 10.1109/SPSC.2008.4686723
URL : https://hal.archives-ouvertes.fr/inria-00291656
The capacity of low-density parity-check codes under message-passing decoding, IEEE Transactions on Information Theory, vol.47, issue.2, pp.599-618, 2001. ,
DOI : 10.1109/18.910577
Practical loss-resilient codes, Proceedings of the twenty-ninth annual ACM symposium on Theory of computing , STOC '97, 1997. ,
DOI : 10.1145/258533.258573
Convergence of iterative decoding, Electronics Letters, vol.35, issue.10, pp.806-808, 1999. ,
DOI : 10.1049/el:19990555
Maxwell's construction: the hidden bridge between maximum-likelihood and iterative decoding, International Symposium onInformation Theory, 2004. ISIT 2004. Proceedings., 2004. ,
DOI : 10.1109/ISIT.2004.1365262
Conservation laws for coding, 2006. ,
Codes al-fec hautes performances pour les canaux défacements : variations autour des codes ldpc, 2010. ,
Raptor forward error correction scheme for object delivery, IETF Request for Comments, p.5053, 2007. ,
DOI : 10.17487/rfc5053
Iterative decoding methods based on low-density graphs, 2007. ,
RS + LDPC-Staircase codes for the erasure channel: Standards, usage and performance, 2013 IEEE 9th International Conference on Wireless and Mobile Computing, Networking and Communications (WiMob), 2013. ,
DOI : 10.1109/WiMOB.2013.6673424
