Exact Minimum Density of Codes Identifying Vertices in the Square Grid, SIAM Journal on Discrete Mathematics, vol.19, issue.1, pp.69-82, 2005. ,
DOI : 10.1137/S0895480104444089
General bounds for identifying codes in some infinite regular graphs, Electron. J. Combin, vol.8, issue.1, 2001. ,
Improved identifying codes for the grid ,
New bounds for codes identifying vertices in graphs, Electronic Journal of Combinatorics, vol.6, issue.1, p.19, 1999. ,
New bounds on the minimum density of an identifying code for the infinite hexagonal grid Discrete Applied Math, pp.2910-2924, 2013. ,
Identifying codes in some subgraphs of the square lattice, Theoretical Computer Science, vol.319, issue.1-3, pp.411-421, 2004. ,
DOI : 10.1016/j.tcs.2004.02.007
A family of optimal identifying codes in <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msup><mml:mi mathvariant="double-struck">Z</mml:mi><mml:mn>2</mml:mn></mml:msup></mml:math>, Journal of Combinatorial Theory, Series A, vol.113, issue.8, pp.1760-1763, 2006. ,
DOI : 10.1016/j.jcta.2006.03.011
New lower bound for 2-identifying code in the square grid, Discrete Applied Mathematics, vol.161, issue.13-14, pp.13-142042, 2013. ,
DOI : 10.1016/j.dam.2013.02.032
Optimal lower bound for 2-identifying codes in the hexagonal grid, Paper 38, 2012. ,
On a new class of codes for identifying vertices in graphs, IEEE Transactions on Information Theory, vol.44, issue.2, pp.599-611, 1998. ,
DOI : 10.1109/18.661507
Robust Location Detection With Sensor Networks, IEEE Journal on Selected Areas in Communications, vol.22, issue.6, pp.1016-1025, 2004. ,
DOI : 10.1109/JSAC.2004.830895
Fault-tolerant locating-dominating sets, Discrete Mathematics, vol.249, issue.1-3, pp.179-189, 2002. ,
DOI : 10.1016/S0012-365X(01)00244-8
