Using Multidimensional Sequences For Improvisation In The OMax Paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Automatic music improvisation systems based on the OMax paradigm use training over a one-dimensional sequence to generate original improvisations. Different systems use different heuristics to guide the improvisation but none of these benefits from training over a multidimensional sequence. We propose a system creating improvisation in a closer way to a human improviser where the intuition of a context is enriched with knowledge. This system combines a probabilistic model taking into account the multidimen-sional aspect of music trained on a corpus, with a factor oracle. The probabilistic model is constructed by interpolating sub-models and represents the knowledge of the system, while the factor oracle (structure used in OMax) represents the context. The results show the potential of such a system to perform better navigation in the factor oracle, guided by the knowledge on several dimensions.
Using Multidimensional Sequences For Improvisation In The OMax Paradigm (SMC2016).pdf (171.62 Ko) Télécharger le fichier
hal-01346797 , version 1 (19-07-2016)
  • HAL Id : hal-01346797 , version 1
Ken Déguernel, Emmanuel Vincent, Gérard Assayag. Using Multidimensional Sequences For Improvisation In The OMax Paradigm. 13th Sound and Music Computing Conference, Aug 2016, Hamburg, Germany. ⟨hal-01346797⟩
510 Consultations
414 Téléchargements
