How far is far enough? Towards an adaptive and " site-centric " modelling integrating co-visibility constraints for optimal land use - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, we propose a renewed site-centric solution that allows us to characterize a specific region of interest by defining the extent of the surroundings that influence sunlight exposure. The proposed method is a mix of an adaptive refinement and a visual-based clipping technique. This method has been implemented in the SketchUp context and applied to three sites located next to the French historical thermal town of Aix-les-Bains.
spatial_accuracy-2016.pdf (1.39 Mo) Télécharger le fichier
hal-01347157 , version 1 (25-07-2016)
  • HAL Id : hal-01347157 , version 1
Valerio Signorelli, Thomas Leduc, Guillaume Chauvat. How far is far enough? Towards an adaptive and " site-centric " modelling integrating co-visibility constraints for optimal land use. Spatial Accuracy 2016, Jul 2016, Montpellier, France. pp.233-240. ⟨hal-01347157⟩
364 Consultations
121 Téléchargements
