Discontinuous automatic control, 1953. ,
DOI : 10.1515/9781400877218
Relay Control Systems, Moscow: Nauka, 1984. ,
Discontinuous Control Systems: Frequency-Domain Analysis and Design, 2009. ,
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007. ,
DOI : 10.1016/j.automatica.2006.10.008
A survey of applications of second-order sliding mode control to mechanical systems, International Journal of Control, vol.76, issue.9-10, pp.875-892, 2003. ,
DOI : 10.1080/0020717031000099010
Unified Lyapunov function for a finite-time stability analysis of relay second-order sliding mode control systems, IMA Journal of Mathematical Control and Information, vol.29, issue.4, pp.529-550, 2012. ,
DOI : 10.1093/imamci/dns007
The invariance conditions in variable structure systems, Automatica, vol.5, issue.3, pp.287-295, 1969. ,
DOI : 10.1016/0005-1098(69)90071-5
Switched affine systems control design with application to DC???DC converters, IET Control Theory & Applications, vol.4, issue.7, pp.1201-1210, 2010. ,
DOI : 10.1049/iet-cta.2009.0246
A bilinear input-output model with state-dependent delay for separated flow control, 2016 European Control Conference (ECC), 2016. ,
DOI : 10.1109/ECC.2016.7810532
URL : https://hal.archives-ouvertes.fr/hal-01298166
An introduction to hybrid dynamical systems, 2000. ,
DOI : 10.1007/BFb0109998
A Nonconservative LMI Condition for Stability of Switched Systems With Guaranteed Dwell Time, IEEE Transactions on Automatic Control, vol.57, issue.5, pp.1297-1302, 2012. ,
DOI : 10.1109/TAC.2011.2174665
Stability Criteria for Switched and Hybrid Systems, SIAM Review, vol.49, issue.4, pp.545-592, 2007. ,
DOI : 10.1137/05063516X
Quadratic stabilization of a switched affine system about a nonequilibrium point, Proceeding of the, 2004. ,
On Practical Stability and Stabilization of Hybrid and Switched Systems, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1897-1903, 2005. ,
DOI : 10.1007/978-3-540-24743-2_41
Variable Structure Control With Generalized Relays: A Simple Convex Optimization Approach, IEEE Transactions on Automatic Control, vol.60, issue.2, pp.497-502, 2015. ,
DOI : 10.1109/TAC.2014.2331417
URL : https://hal.archives-ouvertes.fr/hal-01006389
Power Electronic Converters Modeling and Control: with Case Studies, 2014. ,
DOI : 10.1007/978-1-4471-5478-5
URL : https://hal.archives-ouvertes.fr/hal-00848243
A solution of the problem of synthesis using a controllability function, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
On finite-time stabilization via relay feedback control, 2015 54th IEEE Conference on Decision and Control (CDC), pp.4098-4102, 2015. ,
DOI : 10.1109/CDC.2015.7402857
URL : https://hal.archives-ouvertes.fr/hal-01212598
Simplex sliding mode control of multi-input systems with chattering reduction and mono-directional actuators, Automatica, vol.47, issue.11, pp.2433-2437, 2011. ,
DOI : 10.1016/j.automatica.2011.08.011
Vector method of design of sliding motion and simplex algorithms, Automation and Remote Control, vol.46, pp.830-837, 1985. ,
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10, pp.69-90, 2016. ,
DOI : 10.1002/rnc.3297
URL : https://hal.archives-ouvertes.fr/hal-01160052
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Introduction to calculus and analysis (, 2000. ,
Block control principle I, Automation and Remote Control, vol.51, issue.5, pp.601-609, 1990. ,
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
A new homogeneous quasi-continuous second order sliding mode control, Latinamerican Congress on Automatic Control, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01090716
