Sufficient dimension reduction and prediction in regression, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.68, issue.3, pp.4385-4405, 2009. ,
DOI : 10.1198/016214503000000927
URL : http://rsta.royalsocietypublishing.org/content/roypta/367/1906/4385.full.pdf
Robust Bayesian clustering, Neural Networks, vol.20, issue.1, pp.129-138, 2007. ,
DOI : 10.1016/j.neunet.2006.06.009
URL : http://www.cs.ucl.ac.uk/staff/c.archambeau/publ/nn_ca07_web.pdf
Mixtures of Factor Analyzers with Common Factor Loadings: Applications to the Clustering and Visualization of High-Dimensional Data, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.7, pp.1298-1309, 2010. ,
DOI : 10.1109/TPAMI.2009.149
Retrieval of Mars surface physical properties from OMEGA hyperspectral images using regularized sliced inverse regression, Journal of Geophysical Research, vol.20, issue.2 ,
DOI : 10.1137/1.9780898717921
URL : https://hal.archives-ouvertes.fr/inria-00276116
Robust Bayesian mixture modelling, Neurocomputing, vol.64, pp.235-252, 2005. ,
High-dimensional data clustering, Computational Statistics & Data Analysis, vol.52, issue.1, pp.502-519, 2007. ,
DOI : 10.1016/j.csda.2007.02.009
URL : https://hal.archives-ouvertes.fr/inria-00548591
Random forests, Machine Learning, vol.45, issue.1, pp.5-32, 2001. ,
DOI : 10.1023/A:1010933404324
Non-Normal Mixtures of Experts, ArXiv e-prints ,
Fisher Lecture: Dimension Reduction in Regression, Statistical Science, vol.22, issue.1, pp.1-26, 2007. ,
DOI : 10.1214/088342306000000682
Mixtures of linear regressions, Computational Statistics & Data Analysis, vol.8, issue.3, pp.227-245, 1989. ,
DOI : 10.1016/0167-9473(89)90043-1
High-dimensional regression with gaussian mixtures and partially-latent response variables, Statistics and Computing, vol.19, issue.11, pp.893-911, 2015. ,
DOI : 10.1109/TNN.2008.2003467
URL : https://hal.archives-ouvertes.fr/hal-01107604
Finite mixture regression: A sparse variable selection by model selection for clustering, Electronic Journal of Statistics, vol.9, issue.2, pp.2642-2674, 2015. ,
DOI : 10.1214/15-EJS1082
URL : https://hal.archives-ouvertes.fr/hal-01060079
Bayesian robust inference of sample selection using selection- models, Journal of Multivariate Analysis, vol.124, pp.451-464, 2014. ,
DOI : 10.1016/j.jmva.2013.11.014
Distribution, The American Statistician, vol.40, issue.3, pp.293-295, 2016. ,
DOI : 10.1080/01621459.1987.10478458
URL : https://hal.archives-ouvertes.fr/hal-01420274
A new family of multivariate heavy-tailed distributions with variable marginal amounts of tailweight: application to robust clustering, Statistics and Computing, vol.94, issue.1, pp.971-984, 2014. ,
DOI : 10.1016/S0378-3758(00)00208-1
Multivariate Adaptive Regression Splines, The Annals of Statistics, vol.19, issue.1, pp.1-141, 1991. ,
DOI : 10.1214/aos/1176347963
Finite Mixture and Markov Switching Models, 2006. ,
Robust estimation of mixtures of regressions with random covariates, via trimming and constraints, Statistics and Computing, vol.71, issue.2, pp.27-377, 2017. ,
DOI : 10.1016/j.csda.2013.07.019
Nonlinear Inference and Cluster-Weighted Modeling, Annals of the New York Academy of Sciences, vol.808, issue.1 Nonlinear Sig, pp.18-24, 1997. ,
DOI : 10.1103/PhysRevLett.65.945
A Markov model for switching regressions, Journal of Econometrics, vol.1, issue.1, pp.3-15, 1973. ,
DOI : 10.1016/0304-4076(73)90002-X
Identifiablity of Models for Clusterwise Linear Regression, Journal of Classification, vol.17, issue.2, pp.273-296, 2000. ,
DOI : 10.1007/s003570000022
Local Statistical Modeling via a Cluster-Weighted Approach with Elliptical Distributions, Journal of Classification, vol.71, issue.3, pp.363-401, 2012. ,
DOI : 10.1007/978-1-4615-4651-1
distributions, Journal of Statistical Planning and Inference, vol.177, pp.50-63, 2016. ,
DOI : 10.1016/j.jspi.2016.04.004
URL : https://hal.archives-ouvertes.fr/cea-01508502
Finite mixtures of multivariate skew t-distributions: some recent and new results, Statistics and Computing, vol.82, issue.4, pp.181-202, 2014. ,
DOI : 10.1109/DICTA.2009.88
Sliced Inverse Regression for Dimension Reduction, Journal of the American Statistical Association, vol.13, issue.414, pp.316-327, 1991. ,
DOI : 10.1214/aos/1176345514
URL : http://www.unc.edu/~chongz/Spring2012/SIR.pdf
Robust mixture modeling using multivariate skew t??distributions, Statistics and Computing, vol.14, issue.3, pp.343-356, 2010. ,
DOI : 10.1002/9780470191613
Robit regression: A simple robust alternative to logistic and probit regression, Applied Bayesian Modeling and Causal Inference from Incomplete-data Perspectives, pp.227-238, 2004. ,
Model, Journal of the American Statistical Association, vol.14, issue.497, pp.304-317, 2012. ,
DOI : 10.2307/146317
The EM Algorithm-an Old Folk-song Sung to a Fast New Tune, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.59, issue.3, pp.511-567, 1997. ,
DOI : 10.1111/1467-9868.00082
Robust mixture modeling using the t distribution, Statistics and Computing, vol.10, issue.4, pp.339-348, 2000. ,
DOI : 10.1023/A:1008981510081
Distribution, Journal of Computational and Graphical Statistics, vol.10, issue.2, pp.249-276, 2001. ,
DOI : 10.1198/10618600152628059
URL : https://hal.archives-ouvertes.fr/hal-00615365
Overview and Recent Advances in Partial Least Squares, Subspace, Latent Structure and Feature Selection, pp.34-51, 2006. ,
DOI : 10.1002/(SICI)1097-0193(1997)5:4<254::AID-HBM9>3.0.CO;2-2
???1-penalization for mixture regression models, TEST, vol.101, issue.2, pp.209-256, 2010. ,
DOI : 10.1007/978-1-4757-2545-2
Clustering and classification via cluster-weighted factor analyzers, Advances in Data Analysis and Classification, vol.5, issue.3, pp.5-40, 2013. ,
DOI : 10.1207/s15327906mbr0503_6
URL : http://arxiv.org/pdf/1209.6463.pdf
Cluster-weighted $$t$$ t -factor analyzers for robust model-based clustering and dimension reduction, Statistical Methods & Applications, vol.7, issue.1, pp.623-649, 2015. ,
DOI : 10.1007/s11634-013-0124-8
Sparse Bayesian learning and the relevance vector machine, J. Machine Learning Res, vol.1, pp.211-244, 2001. ,
Statistical Learning Theory ,
Location and scale mixtures of Gaussians with flexible tail behaviour: Properties, inference and application to multivariate clustering, Computational Statistics & Data Analysis, vol.90, pp.90-61, 2015. ,
DOI : 10.1016/j.csda.2015.04.008
URL : https://hal.archives-ouvertes.fr/hal-01254178
Kernel Sliced Inverse Regression with Applications to Classification, Journal of Computational and Graphical Statistics, vol.17, issue.3, pp.590-610, 2008. ,
DOI : 10.1198/106186008X345161
An alternative model for mixtures of experts, Adv. Neural Inform. Proc. Systems, pp.633-640, 1995. ,
Robust mixture regression using the <mml:math altimg="si171.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>t</mml:mi></mml:math>-distribution, Computational Statistics & Data Analysis, vol.71, pp.116-127, 2014. ,
