Iterative methods for approximate solution of inverse problems, 2004. ,
Convergence rates of convex variational regularization, Inverse Problems, vol.20, issue.5, pp.1411-1421, 2004. ,
DOI : 10.1088/0266-5611/20/5/005
A Semismooth Newton Method for Nonlinear Parameter Identification Problems with Impulsive Noise, SIAM Journal on Imaging Sciences, vol.5, issue.2, pp.505-538, 2012. ,
DOI : 10.1137/110826187
Approximate source conditions for nonlinear ill-posed problems???chances and limitations, Inverse Problems, vol.25, issue.3, p.35003, 2009. ,
DOI : 10.1088/0266-5611/25/3/035003
Accelerated Landweber iteration in Banach spaces, Inverse Problems, vol.26, issue.5, p.55002, 2010. ,
DOI : 10.1088/0266-5611/26/5/055002
A convergence rates result for Tikhonov regularization in Banach spaces with non-smooth operators, Inverse Problems, vol.23, issue.3, pp.987-1010, 2007. ,
DOI : 10.1088/0266-5611/23/3/009
Convergence rates for the iteratively regularized Gauss???Newton method in Banach spaces, Inverse Problems, vol.26, issue.3, p.35007, 2010. ,
DOI : 10.1088/0266-5611/26/3/035007
Iterative Regularization Methods for Nonlinear Ill-posed Problems. de Gruyter, 2007. ,
Convergence of some iterative methods for the regularization of nonlinear ill-posed problems in Banach spaces, Inverse Problems, vol.25, 2009. ,
Improved and extended results for enhanced convergence rates of Tikhonov regularization in Banach spaces, Applicable Analysis, vol.25, issue.11, pp.1729-1743, 2010. ,
DOI : 10.1016/0041-5553(84)90253-2
A Modified Landweber Iteration for Solving Parameter Estimation Problems, Applied Mathematics and Optimization, vol.38, issue.1, pp.45-68, 1998. ,
DOI : 10.1007/s002459900081
Nonlinear iterative methods for linear ill-posed problems in Banach spaces, Inverse Problems, vol.22, issue.1, pp.311-329, 2006. ,
DOI : 10.1088/0266-5611/22/1/017
