Optimal control of an elastic contact problem involving Tresca friction law, Nonlinear Analysis: Theory, Methods & Applications, vol.48, issue.8, pp.1107-1135, 2002. ,
DOI : 10.1016/S0362-546X(00)00241-8
Optimal control of variational inequalities, Research Notes in Mathematics, vol.100, 1984. ,
Singular perturbation for the Dirichlet boundary control of elliptic problems, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.5, pp.2-37, 2003. ,
DOI : 10.1051/m2an:2003057
On a non-isothermal, non-Newtonian lubrication problem with Tresca law: Existence and the behavior of weak solutions, Nonlinear Analysis: Real World Applications, vol.9, issue.2, pp.674-692, 2008. ,
DOI : 10.1016/j.nonrwa.2006.12.012
On a convex combination of solutions to elliptic variational inequalities, Electro. J. Diff. Equations, issue.31, pp.1-10, 2007. ,
Convergence of distributed optimal controls for second kind parabolic variational inequalities, Nonlinear Analysis: Real World Applications, pp.2211-2224, 2011. ,
Probì emes unilatéraux, J. Math. Pures Appl, vol.51, pp.1-162, 1972. ,
Elements of nonlinear Analysis, Birkhäuser Advanced Texts, 2000. ,
DOI : 10.1007/978-3-0348-8428-0
Optimal Control of a Class of Variational Inequalities of the Second Kind, SIAM Journal on Control and Optimization, vol.49, issue.4, pp.1629-1658, 2011. ,
DOI : 10.1137/090764438
Convergence of Distributed Optimal Controls on the Internal Energy in Mixed Elliptic Problems when the Heat Transfer Coefficient Goes to Infinity, Applied Mathematics and Optimization, vol.47, issue.3, pp.213-230, 2003. ,
DOI : 10.1007/s00245-003-0761-y
Convergence of boundary optimal controls problems with restrictions in mixed elliptic Stefan-like problems, Adv. Diff. Eq. and Control Processes, vol.1, pp.113-132, 2008. ,
Low-cost control problems on perforated and nonperforated domains, Proc. Indian Acad. Sci. (Math. Sci.), pp.133-157, 2008. ,
Optimal Control on Perforated Domains, Journal of Mathematical Analysis and Applications, vol.229, issue.2, pp.563-586, 1997. ,
DOI : 10.1006/jmaa.1998.6185
An introduction to variational inequalities and their applications, 1980. ,
DOI : 10.1137/1.9780898719451
A distributed parabolic control with mixed boundary conditions, Asymptotic Anal, pp.227-241, 2007. ,
Contr??le dans les in??quations variationelles elliptiques, Journal of Functional Analysis, vol.22, issue.2, pp.130-185, 1976. ,
DOI : 10.1016/0022-1236(76)90017-3
Obstacle problems in mathematical physics, 1987. ,
Sufficient and/or necessary condition for the heat transfer coefficient on ??1 and the heat flux on ??2 to obtain a steady-state two-phase Stefan problem, Journal of Differential Equations, vol.77, issue.1, pp.16-37, 1989. ,
DOI : 10.1016/0022-0396(89)90155-1
Una familia de problemas que converge hacia el caso estacionario del problema de Stefan a dos fases, Math. Notae, vol.27, pp.157-165, 1979. ,
Optimal control of partial differential equations: Theory, methods and applications, 2010. ,
DOI : 10.1090/gsm/112
