Abstract : We consider a system of transmission of the wave equation with Neumann feedback control that contains a delay term and that acts on the exterior boundary. First, we prove under some assumptions that the closed-loop system generates a C0 −semigroup of contractions on an appropriate Hilbert space. Then, under further assumptions, we show that the closed-loop system is exponentially stable. To establish this result, we introduce a suitable energy function and use multiplier method together with an estimate taken from [3] (Lemma 7.2) and compactness-uniqueness arguments.
https://hal.inria.fr/hal-01347547 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 21, 2016 - 11:20:56 AM Last modification on : Thursday, July 21, 2016 - 5:06:07 PM
Salah-Eddine Rebiai. Exponential Stability of the System of Transmission of the Wave Equation with a Delay Term in the Boundary Feedback. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.276-285, ⟨10.1007/978-3-642-36062-6_28⟩. ⟨hal-01347547⟩
