A Quasi-Infinite Horizon Nonlinear Model Predictive Control Scheme with Guaranteed Stability??????This paper was not presented at any IFAC meeting. This paper was accepted for publication in revised form by Associate Editor W. Bequette under the direction of Editor Prof. S. Skogestad., Automatica, vol.34, issue.10, pp.1205-1217, 1998. ,
DOI : 10.1016/S0005-1098(98)00073-9
Flatness and defect of non-linear systems: introductory theory and examples, International Journal of Control, vol.4, issue.6, pp.1327-1361, 1995. ,
DOI : 10.1109/9.73561
Stability and Incremental Improvement of Suboptimal MPC Without Terminal Constraints, IEEE Transactions on Automatic Control, vol.55, issue.11, pp.2576-2580, 2010. ,
DOI : 10.1109/TAC.2010.2057912
A real-time gradient method for nonlinear model predictive control Frontiers of Model Predictive Control http://www. intechopen.com/books/frontiers-of-model-predictive-control/ a-real-time-gradient-method-for-nonlinear-model-predictive-control, pp.9-28, 2012. ,
On the stability of receding horizon control with a general terminal cost, IEEE Transactions on Automatic Control, vol.50, issue.5, pp.674-678, 2005. ,
DOI : 10.1109/TAC.2005.846597
The bifurcation behavior of tubular reactors, Chemical Engineering Science, vol.37, issue.2, pp.199-222, 1982. ,
DOI : 10.1016/0009-2509(82)80155-3
Motion planning for the heat equation, International Journal of Robust and Nonlinear Control, vol.59, issue.60, pp.629-643, 2000. ,
DOI : 10.1002/1099-1239(20000715)10:8<629::AID-RNC502>3.0.CO;2-N
On the Stability of Constrained MPC Without Terminal Constraint, IEEE Transactions on Automatic Control, vol.51, issue.5, pp.832-836, 2006. ,
DOI : 10.1109/TAC.2006.875014
Optimal Control of Systems Governed by Partial Differential Equations, 1970. ,
DOI : 10.1007/978-3-642-65024-6
Flatness-based boundary control of a class of quasilinear parabolic distributed parameter systems, International Journal of Control, vol.11, issue.15, pp.1219-1230, 2002. ,
DOI : 10.1524/auto.2000.48.8.399
Constrained model predictive control: Stability and optimality, Automatica, vol.36, issue.6, pp.789-814, 2000. ,
DOI : 10.1016/S0005-1098(99)00214-9
Feedforward and feedback tracking control of diffusion?convection? reaction systems using summability methods. Fortschritt-Berichte VDI Nr, 1081. ,
Tracking control for boundary controlled parabolic PDEs with varying parameters: Combining backstepping and differential flatness, Automatica, vol.45, issue.5, pp.1182-1194, 2009. ,
DOI : 10.1016/j.automatica.2009.01.006
A generalization of flatness to nonlinear systems of partial differential equations. Application to the command of a flexible rod, Proc. 5th IFAC NOLCOS, pp.196-200, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00126994
On convergence of a receding horizon method for parabolic boundary control, Optimization Methods and Software, vol.81, issue.2, pp.201-216, 2004. ,
DOI : 10.1137/S1052623499358008
Computationally efficient receding horizon trajectory tracking control for a tubular reactor example, PAMM, vol.12, issue.1, 2012. ,
DOI : 10.1002/pamm.201210349
Trajectory planning and receding horizon tracking control of a quasilinear diffusion-convection-reaction system, Proc. 8th IFAC NOLCOS, pp.587-592, 2010. ,
DOI : 10.3182/20100901-3-IT-2016.00215
Comparative evaluation of nonlinear model predictive and flatness-based two-degree-of-freedom control design in view of industrial application, Journal of Process Control, vol.17, issue.2, pp.129-141, 2007. ,
DOI : 10.1016/j.jprocont.2006.09.002
Trajectory planning for quasilinear parabolic distributed parameter systems based on finite-difference semi-discretizations ,
