The role and use of the stochastic linear-quadratic-Gaussian problem in control system design, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.529-552, 1971. ,
DOI : 10.1109/TAC.1971.1099818
On the synthesis of time-varying LQG weights and noises along optimal control and state trajectories, Optimal Control Applications and Methods, vol.32, issue.3, pp.137-160, 2006. ,
DOI : 10.1002/oca.770
A Kalman decomposition to detect temporal linear system structure, Proceedings European Control Conference, p.pp, 1978. ,
Temporal Linear System Structure, IEEE Transactions on Automatic Control, vol.53, issue.5, pp.1318-1323, 2008. ,
DOI : 10.1109/TAC.2008.921033
Temporal and differential stabilizability and detectability of piecewise constant rank systems, Optimal Control Application & Methods, published online in Wiley Online Library (wileyonline library.com), 2011. ,
DOI : 10.1002/oca.997
Cheap control of the time-invariant regulator, Applied Mathematics & Optimization, vol.7, issue.4, pp.337-354, 1975. ,
DOI : 10.1007/BF01447957
Singular perturbations and order reduction in control theory ??? An overview, Automatica, vol.12, issue.2, pp.123-132, 1976. ,
DOI : 10.1016/0005-1098(76)90076-5
On the behaviour of optimal linear sampled-data regulators???, International Journal of Control, vol.80, issue.2, pp.343-361, 1971. ,
DOI : 10.1287/trsc.2.4.362
The digital optimal regulator and tracker for stochastic time-varying systems, International Journal of Systems Science, vol.23, issue.12, pp.2309-2322, 1992. ,
DOI : 10.1080/00207729208949456
Digital optimal control and LQG compensation of asynchronous and aperiodically sampled nonlinear systems, Proceedings 3rd European Control Conference, pp.496-500, 1995. ,
Temporal Linear System Structure, Proceedings of the ECC, pp.225-230, 2009. ,
Control System Analysis and Design Via the ???Second Method??? of Lyapunov: I???Continuous-Time Systems, Journal of Basic Engineering, vol.82, issue.2, pp.371-393, 1960. ,
DOI : 10.1115/1.3662604
Finite-Time Control of Linear Systems: A Survey, Current trends in nonlinear systems and control,Systems and Control: Foundations & Applications, pp.195-213, 2006. ,
DOI : 10.1007/0-8176-4470-9_11
Finite-time stability of linear time-varying systems with jumps, Automatica, vol.45, issue.5, pp.1354-1358, 2009. ,
DOI : 10.1016/j.automatica.2008.12.016
Minimality and Realization of Discrete Time-Varying Systems, Operator theory: Advances and applications, pp.261-296, 1992. ,
DOI : 10.1007/978-3-0348-8615-4_6
Minimal and non-minimal optimal fixed-order compensators for time-varying discrete-time systems, Automatica, vol.38, issue.1, pp.38157-165, 2002. ,
DOI : 10.1016/S0005-1098(01)00182-0
Balanced Truncation of Linear Time-Varying Systems, IEEE Transactions on Automatic Control, vol.49, issue.2, pp.217-229, 2004. ,
DOI : 10.1109/TAC.2003.822862
Linear systems theory revisited, Automatica, vol.44, issue.7, pp.1686-1696, 2008. ,
DOI : 10.1016/j.automatica.2007.10.021
Computing the Kalman decomposition: An optimal method, IEEE Transactions on Automatic Control, vol.29, issue.1, pp.51-53, 1984. ,
DOI : 10.1109/TAC.1984.1103365
Compensatability and optimal compensation of systems with white parameters in the delta domain, International Journal of Control, vol.29, issue.12, pp.2546-2563, 2010. ,
DOI : 10.1016/j.sysconle.2005.02.010
