A Nonlinear Model Predictive Concept for Control of Two-Phase Flows Governed by the Cahn-Hilliard Navier-Stokes System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michael Hinze
  • Fonction : Auteur
  • PersonId : 986392
Christian Kahle
  • Fonction : Auteur
  • PersonId : 986424
We present a nonlinear model predictive framework for closed-loop control of two-phase flows governed by the Cahn-Hilliard Navier-Stokes system. We adapt the concept for instantaneous control from [6,12,16] to construct distributed closed-loop control strategies for two-phase flows. It is well known that distributed instantaneous control is able to stabilize the Burger’s equation [16] and also the Navier-Stokes system [6,12]. In the present work we provide numerical investigations which indicate that distributed instantaneous control also is well suited to stabilize the Cahn-Hilliard Navier-Stokes system.
978-3-642-36062-6_35_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01347555 , version 1 (21-07-2016)
Paternité
Michael Hinze, Christian Kahle. A Nonlinear Model Predictive Concept for Control of Two-Phase Flows Governed by the Cahn-Hilliard Navier-Stokes System. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.348-357, ⟨10.1007/978-3-642-36062-6_35⟩. ⟨hal-01347555⟩
117 Consultations
195 Téléchargements
