A nitrogen-based model of plankton dynamics in the oceanic mixed layer, Journal of Marine Research, vol.48, issue.3, pp.591-639, 1990. ,
DOI : 10.1357/002224090784984678
Carbon cycling in the upper waters of the Sargasso Sea: I. Numerical simulation of differential carbon and nitrogen fluxes, Deep Sea Research Part I: Oceanographic Research Papers, vol.46, issue.2, pp.205-269, 1999. ,
DOI : 10.1016/S0967-0637(98)00062-4
An intermediate complexity marine ecosystem model for the global domain. Deep-Sea Res. II 49, p.403462, 2002. ,
Modelling diatom and Phaeocystis blooms and nutrient cycles in the Southern Bight of the North Sea: the MIRO model, Marine Ecology Progress Series, vol.289, pp.63-78, 2005. ,
DOI : 10.3354/meps289063
Simultaneous data-based optimization of a 1D-ecosystem model at three locations in the North Atlantic: Part I???Method and parameter estimates, Journal of Marine Research, vol.61, issue.6, pp.765-793, 2003. ,
DOI : 10.1357/002224003322981147
Parameter optimization and uncertainty analysis in a model of oceanic CO2 uptake using a hybrid algorithm and algorithmic differentiation, Nonlinear Analysis: Real World Applications, vol.11, issue.5, 2010. ,
DOI : 10.1016/j.nonrwa.2010.03.006
An eddy-permitting coupled physical-biological model of the North Atlantic: 1. Sensitivity to advection numerics and mixed layer physics, Global Biogeochemical Cycles, vol.350, issue.1, pp.135-160, 1999. ,
DOI : 10.1029/98GB02811
Mathematical formulation of the relationship between photosynthesis and light for phytoplankton, Limnology and Oceanography, vol.21, issue.4, pp.540-547, 1976. ,
DOI : 10.4319/lo.1976.21.4.0540
Configuring an ecosystem model using data from the Bermuda Atlantic time series (BATS) Deep-Sea Res, II, vol.48, pp.1733-1768, 2001. ,
The use of optimisation techniques to model marine ecosystem dynamics at the JGOFS station at 473N 203W, Philos. T. Roy. Soc. B, vol.348, pp.206-209, 1995. ,
Climate change and the timing, magnitude, and composition of the phytoplankton spring bloom, Global Change Biology, vol.44, issue.6, pp.1199-1208, 2008. ,
DOI : 10.1007/s10152-004-0196-0
Introducing Periodic Parameters in a Marine Ecosystem Model using Linear Quadratic Optimal Control, Proceedings of the 25th IFIP TC7 Conference on System Modeling and Optimization, 2012. ,
