Abstract : The paper presents mathematical and implementation challenges associated with testing of embedded software systems with dynamic behavior. These challenges are related to notation of tests, calculation of test coverage, implementation of a test comparator, and automatic generation of test cases. Some author’s ideas and solutions are presented with the help of abstract models that describe behavior of the software systems. The models are represented using the state space (or input/state/output) notation. An application example is given to illustrate theoretical analysis and mathematical formulation.
https://hal.inria.fr/hal-01347582 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 21, 2016 - 11:38:01 AM Last modification on : Thursday, October 4, 2018 - 10:12:02 PM
Pawel Skruch. Mathematical and Implementation Challenges Associated with Testing of the Dynamical Systems. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.538-546, ⟨10.1007/978-3-642-36062-6_54⟩. ⟨hal-01347582⟩
