Moving bottlenecks for the Aw-Rascle-Zhang traffic flow model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series B Année : 2017
We introduce a second order model for traffic flow with moving bottlenecks. The model consists of the 2 × 2 Aw-Rascle-Zhang system with a point-wise flow constraint whose trajectory is governed by an ordinary differential equation. We define two Riemann solvers, characterize the corresponding invariant domains and propose numerical strategies, which are effective in capturing the non-classical shocks due to the constraint activation.
VillaGoatinChalons.pdf (675.46 Ko) Télécharger le fichier
hal-01347925 , version 1 (21-07-2016)
  • HAL Id : hal-01347925 , version 1
Stefano Villa, Paola Goatin, Christophe Chalons. Moving bottlenecks for the Aw-Rascle-Zhang traffic flow model. Discrete and Continuous Dynamical Systems - Series B, 2017, 22 (10), pp.3921-3952. ⟨hal-01347925⟩
962 Consultations
353 Téléchargements
