Importance of leaf area index and forest type when estimating photosynthesis in boreal forests, Remote Sensing of Environment, vol.43, issue.3, pp.303-314, 1993. ,
DOI : 10.1016/0034-4257(93)90072-6
Leaf area index of boreal forests: Theory, techniques, and measurements, Journal of Geophysical Research: Atmospheres, vol.5, issue.D24, pp.29429-29443, 1997. ,
DOI : 10.1029/97JD01107
The Applicability of Different Methods for Retrieving Leaf Area Index of Forests in Red Soil Hilly Regions, Acta Agriculturae Universitatis Jiangxiensis, vol.33, issue.3, pp.508-513, 2011. ,
Inversion of Forest Leaf Area Index Calculated from Multi-source and Multi-angle Remote Sensing Data, Chinese Bulletin of Botany, vol.45, issue.5, pp.566-578, 2010. ,
A comparison of vegetation indices over a global set of TM images for EOS-MODIS. Remote sensing of Environment, pp.440-451, 1997. ,
Fré dé ric Bare.: Review of methods for in situ leaf area index determination Part I. Theories, sensors and hemispherical photography Agricultural and Forest Meteorology, pp.19-35, 2004. ,
Compact Airborne Spectrographic Imager (CASI) used for mapping biophysical parameters of boreal forests, JOURNAL OF GEOPHYSICAL RESEARCH, vol.104, issue.22, pp.27945-27958, 1999. ,
Estimation and validation of land surface broadband albedos and leaf area index from eo-1 ali data, IEEE Transactions on Geoscience and Remote Sensing, vol.41, issue.6, pp.1260-1267, 2003. ,
DOI : 10.1109/TGRS.2003.813203
Comparison and Analysis of MODIS NDVI and MODIS EVI, Remote Sensing Information, vol.6, pp.73-78, 2010. ,
Retrieving Leaf Area Indices for Coniferous Forest in Xingguo County, Jiangxi Province, Use of Landsat ETM + Images, pp.253-258, 2005. ,
Study on LAI Extraction Based on Landsat Image, Nanjing Normal University, 2004. ,
Boreal forest leaf areas index from optical satellite images: model simulations and empirical analyses using data from central Finland, Boreal Environment Research, vol.13, pp.433-443, 2008. ,
Monitoring vegetation systems in the Great Plains with ERTS, Proceedings of the third ERTS Symposium, pp.48-62, 1973. ,
Long-term study of solar radiation regimes in a tropical wet forest using quantum sensors and hemispherical photography, Agricultural and Forest Meteorology, vol.65, issue.1-2, pp.107-127, 1993. ,
DOI : 10.1016/0168-1923(93)90040-O
Retrieval of leaf area index in different vegetation types using high resolution satellite data, Remote Sensing of Environment, vol.86, issue.1, pp.120-131, 2003. ,
DOI : 10.1016/S0034-4257(03)00094-4
Mapping Regional Forest Evapotranspiration and Photosynthesis by Coupling Satellite Data with Ecosystem Simulation, Ecology, vol.70, issue.4, pp.1090-1101, 1989. ,
DOI : 10.2307/1941378
A Simple Biosphere Model (SIB) for Use within General Circulation Models, Journal of the Atmospheric Sciences, vol.43, issue.6, pp.505-531, 1986. ,
DOI : 10.1175/1520-0469(1986)043<0505:ASBMFU>2.0.CO;2
Relationships between Leaf Area Index and Landsat TM Spectral Vegetation Indices across Three Temperate Zone Sites, Remote Sensing of Environment, vol.70, issue.1, pp.52-68, 1999. ,
DOI : 10.1016/S0034-4257(99)00057-7
Theoretical basis and application of Three Gradient Difference Vegetation Index, Science China (Series D), vol.11, issue.33, pp.1094-1102, 2003. ,
Evaluation of Canopy Biophysical Variable Retrieval Performances from the Accumulation of Large Swath Satellite Data, Remote Sensing of Environment, vol.70, issue.3, pp.293-306, 1999. ,
DOI : 10.1016/S0034-4257(99)00045-0
Estimating Method of Forest Leaf Areas Index on Different Space Scales, Scientia Silvae Sinicae, vol.45, issue.6, pp.139-144, 2004. ,
The research status of inversion of leaf area index with hyperspectra l remote sensing, Science of Surveying and Mapping, vol.35, issue.S1, pp.162-164, 2010. ,
Vegetation and Ecological Remote Sensing, 2010. ,
Principles and Analysis of Remote Sensing Application, 2003. ,
Forest canopy leaf area index in Maoershan Mountain: Ground measurement and remote sensing, Chinese Journal of Applied Ecology, vol.21, issue.8, pp.2117-2124, 2010. ,
