China's forest resource inventory, 2005. ,
A rigorous assessment of tree height measurements obtained using airborne lidar and conventional field methods, Canadian Journal of Remote Sensing, vol.102, issue.4, pp.355-366, 2006. ,
DOI : 10.5589/m06-030
LiDAR measurement of sagebrush steppe vegetation heights. Remote Sensing of Environment, pp.135-145, 2006. ,
Forest mensuration 2th ed, 1972. ,
Classifying species of individual trees by intensity and structure features derived from airborne laser scanner data, Remote Sensing of Environment, vol.113, pp.1163-1174, 2009. ,
Study on the Estimation Method of Forest Parameters Using Airbone LiDAR, 2009. ,
Detecting and measuring individual trees using an airborne laser scanner, Photogrammetric Engineering & Remote Sensing, vol.68, issue.9, pp.925-932, 2002. ,
Seeing the trees in the forest: using lidar and multispectral data fusion with local filtering and variable window size for estimating tree height, Photogrammetric Engineering & Remote Sensing, vol.70, issue.5, pp.589-604, 2004. ,
Characterizing vertical forest structure using smallfootprint airborne LiDAR, Remote Sensing of Environment, vol.87, issue.2, pp.171-182, 2003. ,
Detection and analysis of individual leaf-off tree crowns in small footprint, high sampling density lidar data from the eastern deciduous forest in North America, Remote Sensing of Environment, vol.85, pp.290-303, 2003. ,
Single Tree Segmentation Using Airborne Laser Scanner Data in a Structurally Heterogeneous Spruce Forest, Photogrammetric Engineering & Remote Sensing, vol.72, issue.12, pp.721369-1378, 2006. ,
DOI : 10.14358/PERS.72.12.1369
Watersheds in digital spaces: an efficient algorithm based on immersion simulations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.6, pp.583-598, 1991. ,
DOI : 10.1109/34.87344
Implementation of a fast algorithm for segmenting SAR imagery, Scientific and Technical Report, vol.1, issue.1, pp.4-5, 2002. ,
Estimation of timber volume and stem density based on scanning laser altimetry and expected tree size distribution functions, Remote Sensing of Environment, vol.90, issue.3, pp.319-330, 2004. ,
DOI : 10.1016/j.rse.2004.01.006
A study of relation between D and H-Distribution by using the Weibull funtion, Journal of Beijing Forestry University, vol.1, issue.10, pp.40-48, 1988. ,
