On normals and projection operators for surfaces defined by point sets, Proc. of the EG conf. on Point-Based Graphics, 2004. ,
Interpolatory point set surfaces-convexity and hermite data, ACM Trans. on Graphics, issue.10, 2009. ,
Surface reconstruction by voronoi filtering, Discrete & Computational Geometry, p.16, 1999. ,
Computing and rendering point set surfaces, Trans. on Visualization and Computer Graphics, vol.3, issue.7 9, 2003. ,
Voronoi-based variational reconstruction of unoriented point sets, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing), p.23, 2007. ,
Defining point-set surfaces, ACM Trans. on Graphics, vol.5, p.10, 2004. ,
O-snap, Proc. SIGGRAPH), p.22, 2013. ,
DOI : 10.1145/2421636.2421642
1 -sparse reconstruction of sharp point set surfaces, ACM Trans. on Graphics, vol.7, p.14, 2010. ,
Urban ecosystem design, Symposium on Interactive 3D Graphics and Games, pp.167-174, 2011. ,
Piecewise-planar 3d reconstruction with edge and corner regularization, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.19, 2014. ,
A benchmark for surface reconstruction, ACM Trans. on Graphics, p.23, 2013. ,
Image-based reconstruction and synthesis of dense foliage, Proc. SIGGRAPH), p.21, 2013. ,
Shape Analysis with Subspace Symmetries, Computer Graphics Forum, vol.29, issue.2, p.19, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01859.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.221.7014
Reconstruction and representation of 3d objects with radial basis functions, Proc. of ACM SIGGRAPH, 2001. ,
Non-oriented MLS Gradient Fields, Computer Graphics Forum, issue.10, 2013. ,
Robust piecewise-planar 3d reconstruction and completion from largescale unstructured point data, CVPR, p.18, 2010. ,
Ssd: Smooth signed distance surface reconstruction, Computer Graphics Forum, p.12, 2011. ,
Point cloud skeletons via laplacian based contraction, Proc. of IEEE Shape Modeling International, p.17, 2010. ,
A survey of methods for moving least squares surfaces, Proceedings of the Fifth Eurographics/IEEE VGTC conference on Point-Based Graphics Eurographics Association, 2008. ,
Feature-preserving surface reconstruction and simplification from defect-laden point sets, Journal of Mathematical Imaging and Vision, pp.1-14, 2013. ,
Robust smooth feature extraction from point clouds, Proc. of Shape Modeling and Applications, p.13, 2007. ,
Meshflow: interactive visualization of mesh construction sequences, In ACM Trans. on Graphics, p.23, 2011. ,
Scale space meshing of raw data point sets, In Computer Graphics Forum, issue.3, 2011. ,
Model globally, match locally: Efficient and robust 3d object recognition, CVPR, p.18, 2010. ,
Robust moving least-squares fitting with sharp features, Proc. SIGGRAPH), p.13, 2005. ,
Noise-adaptive shape reconstruction from raw point sets, Proc. of the Symposium on Geometry Processing), p.23, 2013. ,
Algebraic point set surfaces, Proc. SIGGRAPH), p.10, 2007. ,
Surface reconstruction from unorganized points, Computer Graphics (Proc. SIGGRAPH), 1992. ,
Robust reconstruction of watertight 3d models from non-uniformly sampled point clouds without normal information, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing), p.13, 2006. ,
Rgb-d mapping: Using kinect-style depth cameras for dense 3d modeling of indoor environments, The International Journal of Robotics Research, issue.5, 2012. ,
Consolidation of unorganized point clouds for surface reconstruction -medial skeleton of point cloud, Proc. SIGGRAPH), pp.11-22, 2009. ,
Edge-aware point set resampling, ACM Transactions on Graphics, vol.32, issue.1, p.14, 2013. ,
DOI : 10.1145/2421636.2421645
Single-view reconstruction via joint analysis of image and shape collections, Proc. SIGGRAPH), 2015. ,
Surface reconstruction from fitted shape primitives, Proc. of Vision modeling and Visualization, p.18, 2008. ,
Patch-graph reconstruction for piecewise smooth surfaces, Proc. of Vision modeling and Visualization, p.13, 2008. ,
Reconstruction of solid models from oriented point sets, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.22, 2005. ,
Poisson surface reconstruction, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.23, 2006. ,
Screened poisson surface reconstruction, ACM Trans. on Graphics, vol.12, p.23, 2013. ,
Guided real-time scanning of indoor objects, In Computer Graphics Forum, vol.8, p.21, 2013. ,
Acquiring 3d indoor environments with variability and repetition, Proc. of ACM SIGGRAPH Asia, vol.3, issue.21, p.23, 2012. ,
Spectral surface reconstruction from noisy point clouds, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.13, 2004. ,
Direct visibility of point sets, Proc. SIGGRAPH), p.16, 2007. ,
Surface reconstruction through point set structuring, Proc. of Eurographics ), p.19, 2013. ,
Global optimization for shape fitting, CVPR, p.15, 2007. ,
Symmetry factored embedding and distance Error bounds and optimal neighborhoods for mls approximation, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing ), 2006. ,
Datadependent MLS for faithful surface approximation, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing ), p.13, 2007. ,
Parameterization-free projection for geometry reconstruction, Proc. SIGGRAPH), p.14, 2007. ,
Databaseassisted object retrieval for real-time 3d reconstruction, Proc. of Eurographics), p.21, 2015. ,
Mesh-independent surface interpolation Geometric Modeling for Scientific Visualization, pp.37-49, 2003. ,
Analysis, reconstruction and manipulation using arterial snakes, Proc. of ACM SIGGRAPH Asia, vol.3, issue.17, p.23, 2010. ,
The digital michelangelo project: 3d scanning of large statues, Proc. of ACM SIGGRAPH, pp.131-144, 2000. ,
Robust and efficient surface reconstruction from range data, Computer Graphics Forum, p.15, 2009. ,
Globfit: consistently fitting primitives by discovering global relations, Proc. SIG- GRAPH), p.20, 2011. ,
Automatic reconstruction of tree skeletal structures from point clouds, Proc. of ACM SIGGRAPH Asia, p.17, 2010. ,
fusion for layer decomposition of urban facades, ICCV, pp.2-3, 2011. ,
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets, Proc. of the Symposium on Geometry Processing), p.17, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01782.x
Hermite radial basis functions implicits Rapter: Rebuilding man-made scenes with regular arrangements of planes, Proc. SIGGRAPH), p.20, 2011. ,
Estimating surface normals in noisy point cloud data, International Journal of Computational Geometry & Applications, issue.5, 2004. ,
Streaming surface reconstruction using wavelets, Computer Graphics Forum, vol.12, p.22, 2008. ,
Symmetry in 3d geometry: Extraction and applications, Computer Graphics Forum (STAR Proceedings of Eurographics), p.19, 2013. ,
Visibility of noisy point cloud data, Computers & Graphics, 2010. ,
A survey of urban reconstruction, Computer Graphics Forum (STAR Proceedings of Eurographics), 2013. ,
Structure-aware shape processing, Computer Graphics Forum (STAR Proceedings of Eurographics), p.19, 2013. ,
KinectFusion: Real-time dense surface mapping and tracking, 2011 10th IEEE International Symposium on Mixed and Augmented Reality, p.24, 2011. ,
DOI : 10.1109/ISMAR.2011.6092378
Approximate image-based tree-modeling using particle flows, Proc. SIGGRAPH), p.17, 2007. ,
Dynamicfusion: Reconstruction and tracking of non-rigid scenes in real-time Smoothing of partition of unity implicit surfaces for noise robust surface reconstruction, CVPRProc. of the Symposium on Geometry Processing), pp.22-33, 2009. ,
Tomographic surface reconstruction from point cloud, Computers & Graphics, p.17, 2015. ,
2d-d lifting for shape reconstruction Instance segmentation of indoor scenes using a coverage loss, ECCV, pp.20-38, 2014. ,
Smartboxes for interactive urban reconstruction, Proc. SIGGRAPH), p.22, 2010. ,
A search-classify approach for cluttered indoor scene understanding, Proc. of ACM SIGGRAPH Asia, vol.8, issue.21, p.23, 2012. ,
Real-time 3d reconstruction at scale using voxel hashing, ACM Transactions on Graphics (TOG), vol.15, p.24, 2013. ,
Multi-level partition of unity implicits, Proc. SIGGRAPH), 2003. ,
Feature preserving point set surfaces based on non-linear kernel regression, In Computer Graphics Forum, vol.4, issue.10, p.14, 2009. ,
Planar shape detection and regularization in tandem, p.20 ,
Poisson image editing, Proc. SIGGRAPH), p.12, 2003. ,
Uncertainty and variability in point cloud surface data, Proc. of the EG conf. on Point-Based Graphics, 2004. ,
Example-based 3d scan completion, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.8, 2005. ,
Discovering structural regularity in 3d geometry, Proc. SIGGRAPH), p.19, 2008. ,
Globally Consistent Space-Time Reconstruction, Computer Graphics Forum, vol.29, issue.2, pp.1633-1642, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01772.x
Modeling and visualization of leaf venation patterns, Proc. SIGGRAPH), pp.702-711, 2005. ,
DOI : 10.1145/1073204.1073251
Reconstructing shape boundaries with multimodal constraints, Computers & Graphics, p.19, 2013. ,
Space-time surface reconstruction using incompressible flow, ACM Trans. on Graphics, vol.27, issue.110 4, 2008. ,
DOI : 10.1145/1409060.1409063
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.6536
3D Models for Cultural Heritage: Beyond Plain Visualization, Computer, vol.44, issue.7, pp.48-55, 2011. ,
DOI : 10.1109/MC.2011.196
Completion and reconstruction with primitive shapes, Computer Graphics ForumProc. of Eurographics), vol.3, issue.8, p.18, 2009. ,
Provenance for visualizations: Reproducibility and beyond, Comp. in Science & Engineering, p.23, 2007. ,
Structure recovery by part assembly, Proc. of ACM SIGGRAPH Asia, p.21, 2012. ,
Adaptive partitioning of urban facades, Proc. of ACM SIGGRAPH Asia, vol.19, p.20, 2011. ,
Estimating image depth using shape collections, Proc. SIGGRAPH), 2014. ,
Competing Fronts for Coarse?to?Fine Surface Reconstruction, Proc. of Eurographics), p.18, 2006. ,
DOI : 10.1109/83.661186
Interactive topology-aware surface reconstruction, Proc. SIGGRAPH), p.23, 2007. ,
DOI : 10.1145/1276377.1276431
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.413.4995
Interpolating and approximating implicit surfaces from polygon soup, ACM Trans. on Graphics, issue.10, 2004. ,
Direct (re)meshing for efficient surface processing Cone carving for surface reconstruction, Proc. of ACM SIGGRAPH Asia, pp.13-16, 2006. ,
Efficient ransac for point-cloud shape detection, Computer Graphics Forum, vol.5, issue.19, pp.18-20, 2007. ,
An interactive approach to semantic modeling of indoor scenes with an RGBD camera, ACM Transactions on Graphics, vol.31, issue.6, pp.20-23, 2012. ,
DOI : 10.1145/2366145.2366155
VASE: Volume-Aware Surface Evolution for Surface Reconstruction from Incomplete Point Clouds, Proc. of the Symposium on Geometry Processing), p.18, 2011. ,
DOI : 10.1111/j.1467-8659.2011.02030.x
Curve skeleton extraction from incomplete point cloud, Proc. SIGGRAPH), p.18, 2009. ,
Automatic extraction of manhattan-world building masses from 3d laser range scans Watertight scenes from urban lidar and planar surfaces, COHEN-OR D.: A survey on shape correspondence. In Computer Graphics Forum, p.19, 2011. ,
LOD Generation for Urban Scenes, p.23, 2015. ,
Realtime performance-based facial animation ,
Scattered Data Approximation, 2005. ,
A level-set approach to 3D reconstruction from range data, International Journal of Computer Vision, vol.29, issue.3, pp.203-231, 1998. ,
Grammar-based 3d facade segmentation and reconstruction, Computers & Graphics, vol.19, p.20, 2012. ,
Bandwidth selection and reconstruction quality in point-based surfaces, Trans. on Visualization and Computer Graphics, issue.4, 2009. ,
Reconstructing the worlds museums, ECCV, p.19, 2012. ,
Robust surface reconstruction via dictionary learning, ACM Transactions on Graphics, vol.33, issue.6, p.14, 2014. ,
DOI : 10.1145/2661229.2661263
Morfit: Interactive surface reconstruction from incomplete point clouds with curve-driven topology and geometry control, Proc. of ACM SIGGRAPH Asia, vol.3, issue.9, p.22, 2014. ,
Proactive 3d scanning of inaccessible parts, Proc. SIGGRAPH), p.22, 2014. ,
Shadingbased refinement on volumetric signed distance functions, Proc. SIGGRAPH), p.15, 2015. ,
Depth camera tracking with contour cues, CVPR, p.15, 2015. ,
2.5 d building modeling by discovering global regularities, CVPR, p.20, 2012. ,
A globally optimal algorithm for robust tv-l1 range image integration, ICCV, p.15, 2007. ,
Non-local scan consolidation for 3d urban scenes, Proc. SIGGRAPH), p.20, 2010. ,
Data-driven flower petal modeling with botany priors, CVPR, p.21, 2014. ,
