Consensus and Cooperation in Networked Multi-Agent Systems, Proc. of the IEEE, pp.215-233, 2007. ,
DOI : 10.1109/JPROC.2006.887293
Global and robust formation-shape stabilization of relative sensing networks, Automatica, vol.45, issue.12, pp.2754-2762, 2009. ,
DOI : 10.1016/j.automatica.2009.09.019
Distributed formation control without a global reference frame, 2014 American Control Conference, pp.3862-3867, 2014. ,
DOI : 10.1109/ACC.2014.6859235
Rigid graph control architectures for autonomous formations, IEEE Control Systems Magazine, vol.28, issue.6, pp.48-63, 2008. ,
DOI : 10.1109/MCS.2008.929280
Stabilisation of infinitesimally rigid formations of multi-robot networks, International Journal of Control, vol.34, issue.3, pp.423-439, 2009. ,
DOI : 10.2307/1969908
Controlling Rigid Formations of Mobile Agents Under Inconsistent Measurements, IEEE Transactions on Robotics, vol.31, issue.1, pp.31-39, 2015. ,
DOI : 10.1109/TRO.2014.2373145
Decentralized rigidity maintenance control with range measurements for multi-robot systems, The International Journal of Robotics Research, vol.46, issue.2, pp.105-128, 2015. ,
DOI : 10.1177/0278364914546173
URL : https://hal.archives-ouvertes.fr/hal-01076423
Stabilization of rigid formations with direction-only constraints, IEEE Conference on Decision and Control and European Control Conference, pp.746-752, 2011. ,
DOI : 10.1109/CDC.2011.6160743
Formation shape control based on bearing rigidity, International Journal of Control, vol.145, issue.9, pp.1361-1379, 2012. ,
DOI : 10.1016/j.automatica.2006.08.025
Decentralized control of parallel rigid formations with direction constraints and bearing measurements, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5310-5317, 2012. ,
DOI : 10.1109/CDC.2012.6426034
Scale-free coordinates for multi-robot systems with bearing-only sensors, The International Journal of Robotics Research, vol.197, issue.2, pp.1459-1474, 2013. ,
DOI : 10.1109/IROS.2003.1249745
Bearing Rigidity and Almost Global Bearing-Only Formation Stabilization, IEEE Transactions on Automatic Control, vol.61, issue.5, pp.1255-1268, 2016. ,
DOI : 10.1109/TAC.2015.2459191
Using angle of arrival (bearing) information for localization in robot networks, Turkish J. of Elec. Eng. & Comput. Sci, vol.15, issue.2, pp.169-186, 2007. ,
A distributed gradient method for localization of formations using relative range measurements, 2010 IEEE International Symposium on Computer-Aided Control System Design, pp.1146-1151, 2010. ,
DOI : 10.1109/CACSD.2010.5612764
Analysis of Noisy Bearing-Only Network Localization, IEEE Transactions on Automatic Control, vol.58, issue.1, pp.247-252, 2013. ,
DOI : 10.1109/TAC.2012.2206693
Rigid components identification and rigidity enforcement in bearing-only localization using the graph cycle basis, ACC, pp.3911-3918, 2015. ,
Modeling and Control of UAV Bearing Formations with Bilateral High-level Steering, Special Issue on 3D Exploration, Mapping, and Surveillance, pp.1504-1525, 2012. ,
DOI : 10.1109/TRO.2012.2196304
Bearing-only formation control using an SE(2) rigidity theory, 2015 54th IEEE Conference on Decision and Control (CDC), pp.6121-6126, 2015. ,
DOI : 10.1109/CDC.2015.7403182
URL : https://hal.archives-ouvertes.fr/hal-01187978
Algebraic Graph Theory, 2001. ,
DOI : 10.1007/978-1-4613-0163-9
Sensor and network topologies of formations with direction, bearing and angle information between agents, 42nd IEEE International Conference on Decision and Control (IEEE Cat. No.03CH37475), pp.3064-3069, 2003. ,
DOI : 10.1109/CDC.2003.1273093
Rigidity theory in SE(2) for unscaled relative position estimation using only bearing measurements, 2014 European Control Conference (ECC), pp.2703-2708, 2014. ,
DOI : 10.1109/ECC.2014.6862558
URL : https://hal.archives-ouvertes.fr/hal-00994989
Decentralized estimation and control of graph connectivity for mobile sensor networks, Automatica, vol.46, issue.2, pp.390-396, 2010. ,
DOI : 10.1016/j.automatica.2009.11.012
A passivity-based decentralized strategy for generalized connectivity maintenance, The International Journal of Robotics Research, vol.54, issue.6, pp.299-323, 2013. ,
DOI : 10.1177/0278364912469671
URL : https://hal.archives-ouvertes.fr/hal-00910385
Stability and Convergence Properties of Dynamic Average Consensus Estimators, Proceedings of the 45th IEEE Conference on Decision and Control, pp.338-343, 2006. ,
DOI : 10.1109/CDC.2006.377078
Feature Depth Observation for Image-based Visual Servoing: Theory and Experiments, The International Journal of Robotics Research, vol.27, issue.10, pp.1093-1116, 2008. ,
DOI : 10.1177/0278364908096706
Active Structure From Motion: Application to Point, Sphere, and Cylinder, IEEE Transactions on Robotics, vol.30, issue.6, pp.1499-1513, 2014. ,
DOI : 10.1109/TRO.2014.2365652
URL : https://hal.archives-ouvertes.fr/hal-01086866
Active decentralized scale estimation for bearing-based localization, 2016 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), 2016. ,
DOI : 10.1109/IROS.2016.7759746
URL : https://hal.archives-ouvertes.fr/hal-01355789
The TeleKyb framework for a modular and extendible ROS-based quadrotor control, 2013 European Conference on Mobile Robots, pp.19-25, 2013. ,
DOI : 10.1109/ECMR.2013.6698814
URL : https://hal.archives-ouvertes.fr/hal-00908803
