An electrical gearbox by means of pole variation for induction and superconducting disc motor, Journal of Physics: Conference Series, vol.97, pp.97-012221, 2007. ,
DOI : 10.1088/1742-6596/97/1/012221
Proof-of-concept of a variable poles multiphase motor, Proceedings of the Flux Users Conference, 2009. ,
Radial and Axial Flux Superconducting Motors in a Levitating Rotor Configuration, IEEE Transactions on Applied Superconductiviy, vol.9, issue.2, 1999. ,
Torque from hysteresis machines with type-II superconducting segmented rotors, Physica C: Superconductivity, vol.331, issue.2, pp.133-140, 2000. ,
DOI : 10.1016/S0921-4534(00)00014-9
Experimental and theoretical study of electrical machines with bulk HTS elements, Power Electronics and Motion Control Conference, pp.568-570, 2004. ,
Numerical and experimental comparison of electromechanical properties and efficiency of HTS and ferromagnetic hysteresis motors, Journal of Physics: Conference Series, vol.97, pp.1742-6596, 2008. ,
DOI : 10.1088/1742-6596/97/1/012218
Digital simulation of the hysteresis motor, Proceedings of the IEEE, pp.1533-1537, 1973. ,
DOI : 10.1049/piee.1973.0315
Analysis of hysteresis motor using finite element method and magnetization-dependent model, IEEE Transactions on Magnetics, vol.36, issue.4, pp.685-688, 2000. ,
Induction Motors for Two Synchronous Speeds, IEEE Transactions on Power Apparatus and Systems, pp.90-495, 1971. ,
Design considerations for an automotive integrated starter-generator with pole-phase modulation, Conference Record of the 2001 IEEE Industry Applications Conference. 36th IAS Annual Meeting (Cat. No.01CH37248), pp.2366-2373, 2001. ,
DOI : 10.1109/IAS.2001.955953
