Electric Power Systems: Advanced Forecasting Techniques and Optimal Generation Scheduling, 2012. ,
DOI : 10.1201/b11649
Dynamic economic dispatch solution using fast evolutionary programming with swarm direction, 2009 4th IEEE Conference on Industrial Electronics and Applications, pp.1538-1544, 2009. ,
DOI : 10.1109/ICIEA.2009.5138452
Application of soft computing methods for Economic Dispatch in Power Systems, International Journal of Electrical and Electronics Engineering, issue.2, pp.538-543, 2009. ,
Particle swarm optimization to solving the economic dispatch considering the generator constraints, IEEE Transactions on Power Systems, pp.1187-1195, 2003. ,
DOI : 10.1109/TPWRS.2003.814889
An improved tabu search for economic dispatch with multiple minima, IEEE Transactions on Power Systems, pp.108-112, 2002. ,
A New Particle Swarm Optimization Solution to Nonconvex Economic Dispatch Problems, IEEE Transactions on Power Systems, vol.22, issue.1, pp.42-51, 2007. ,
DOI : 10.1109/TPWRS.2006.889132
An Improved Particle Swarm Optimization for Nonconvex Economic Dispatch Problems, IEEE Transactions on Power Systems, pp.156-166, 2010. ,
Evolutionary programming techniques for economic load dispatch, IEEE Transactions on Evolutionary Computation, vol.7, issue.1, pp.83-92, 2003. ,
DOI : 10.1109/TEVC.2002.806788
PSO embedded evolutionary programming technique for nonconvex economic load dispatch, Power Systems Conference and Exposition, pp.66-71, 2004. ,
Improved Genetic Algorithm for Power Economic Dispatch of Units With Valve-Point Effects and Multiple Fuels, IEEE Transactions on Power Systems, pp.1690-1699, 2005. ,
DOI : 10.1109/TPWRS.2005.857924
Fundamental of Optimization by Swarm Inteligence: an Overview, Fundamentos de Otimização por Inteligência de Enxames: uma Visão Geral, In: Revista Contole & Automação, vol.20, issue.3, 2009. ,
Combining of Chaotic Differential Evolution and Quadratic Programming for Economic Dispatch Optimization With Valve-Point Effect, IEEE Transactions on Power Systems, vol.21, issue.2, pp.989-996, 2006. ,
A GA-API Solution for the Economic Dispatch of Generation in Power System Operation, IEEE Transactions on Power Systems, pp.233-242, 2012. ,
DOI : 10.1109/TPWRS.2011.2168833
A Particle Swarm Optimization for Economic Dispatch With Nonsmooth Cost Functions, IEEE Transactions on Power Systems, pp.34-42, 2005. ,
DOI : 10.1109/TPWRS.2004.831275
SCO ? Sensing Cloud Optimization Applied to a Non-convex and Constrained Dynamic Economical Dispatch, IEEE Transactions on Power Systems ,
