Using Variable Width RF Integrated Inductors for Quality Factor Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pedro Almeida
  • Fonction : Auteur
  • PersonId : 986744
Pedro Pereira
  • Fonction : Auteur
  • PersonId : 986709
Helena Fino
  • Fonction : Auteur
  • PersonId : 986711
The advancement of CMOS technology led to the integration of more complex functions. In the particular of wireless transceivers, integrated LC tanks are becoming popular both for VCOs and integrated filters [1]. For RF applications the main challenge is still the design of integrated inductors with the maximum quality factor. For that purpose, tapered, i.e., variable width inductors have been proposed in the literature. In this paper, analytical expressions for the determination the pi-model parameters, for the characterization of variable width integrated inductors are proposed. The expressions rely exclusively on geometrical and technological parameters, thus granting the rapid adaptation of the model to different technologies. The results obtained with the model are compared against simulation with ASITIC, showing errors below 10%. The model is then integrated into an optimization procedure where inductors with a quality factor improvement in the order of 20-30% are obtained, when compared with fixed width inductors.
978-3-642-37291-9_67_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01348809 , version 1 (25-07-2016)
Paternité
Pedro Almeida, Pedro Pereira, Helena Fino. Using Variable Width RF Integrated Inductors for Quality Factor Optimization. 4th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2013, Costa de Caparica, Portugal. pp.619-627, ⟨10.1007/978-3-642-37291-9_67⟩. ⟨hal-01348809⟩
97 Consultations
327 Téléchargements
