A calculation of the viscous force exerted by a flowing fluid on a dense swarm of particles, Flow, Turbulence and Combustion, vol.15, issue.1, pp.27-34, 1949. ,
DOI : 10.1002/andp.19063240204
An immersed boundary method using unstructured anisotropic mesh adaptation combined with level-sets and penalization techniques, Journal of Computational Physics, vol.257, pp.83-101, 2014. ,
DOI : 10.1016/j.jcp.2013.08.052
URL : https://hal.archives-ouvertes.fr/hal-00940302
On the Construction and Comparison of Difference Schemes, SIAM Journal on Numerical Analysis, vol.5, issue.3, pp.506-517, 1968. ,
DOI : 10.1137/0705041
An adaptive, residual based, splitting approach for the penalized Navier Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.303, pp.208-230, 2016. ,
DOI : 10.1016/j.cma.2016.01.009
URL : https://hal.archives-ouvertes.fr/hal-01275807
Adaptivity with moving grids, Acta Numerica, vol.20, issue.5, pp.111-241, 2009. ,
DOI : 10.1016/j.jcp.2007.01.019
Space-Time accurate anisotropic adaptation and stabilized finite element methods for the resolution of unsteady CFD problems. Theses, 2014. ,
Mesh adaptation for simulation of unsteady flow with moving immersed boundaries, International Journal for Numerical Methods in Fluids, vol.230, issue.8, pp.453-477, 2013. ,
DOI : 10.1002/fld.3751
Computation of the signed distance function to a discrete contour on adapted triangulation, Calcolo, vol.74, issue.3, pp.193-219, 2012. ,
DOI : 10.1007/s10092-011-0051-z
High order fluctuation schemes on triangular meshes, J Sci Comput, vol.19, pp.885-7474, 2003. ,
High-Order Preserving Residual Distribution Schemes for Advection-Diffusion Scalar Problems on Arbitrary Grids, SIAM Journal on Scientific Computing, vol.36, issue.3, pp.955-983, 2014. ,
DOI : 10.1137/12090143X
URL : https://hal.archives-ouvertes.fr/hal-00758930
Explicit Runge???Kutta residual distribution schemes for time dependent problems: Second order case, Journal of Computational Physics, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Contributions to the development of residual discretizations for hyperbolic conservation laws with application to shallow water flows, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00651688
A second-order-accurate monotone implicit fluctuation splitting scheme for unsteady problems, Journal of Computational Physics, vol.208, issue.1, pp.1-33, 2005. ,
DOI : 10.1016/j.jcp.2004.11.023
Mesh Moving Techniques for Fluid-Structure Interactions With Large Displacements, Journal of Applied Mechanics, vol.70, issue.1, pp.58-63, 2003. ,
DOI : 10.1115/1.1530635
Adaptive Mesh Methods for One- and Two-Dimensional Hyperbolic Conservation Laws, SIAM Journal on Numerical Analysis, vol.41, issue.2, pp.487-515, 2003. ,
DOI : 10.1137/S003614290138437X
Efficient computation of dendritic growth with r-adaptive finite element methods, Journal of Computational Physics, vol.227, issue.12, pp.5984-6000, 2008. ,
DOI : 10.1016/j.jcp.2008.02.016
Second-Order Accurate Godunov Scheme for??Multicomponent Flows on Moving Triangular Meshes, Journal of Scientific Computing, vol.1, issue.1, pp.64-86, 2008. ,
DOI : 10.1007/s10915-007-9162-8
An ALE Formulation for Explicit Runge???Kutta Residual Distribution, Journal of Scientific Computing, vol.215, issue.1, pp.502-547, 2015. ,
DOI : 10.1007/s10915-014-9910-5
URL : https://hal.archives-ouvertes.fr/hal-01087947
Construction of second order accurate monotone and stable residual distribution schemes for unsteady flow problems, Journal of Computational Physics, vol.188, issue.1, pp.16-55, 2003. ,
DOI : 10.1016/S0021-9991(03)00084-6
Development of a high order residual distribution method for Navier Stokes and RANS equation, 2013. ,
Ponthot, and A. Rodríguez-Ferran. Encyclopedia of Computational Mechanics Arbitrary Lagrangian-Eulerian Methods, 2004. ,
The Discrete Geometric Conservation Law and the Nonlinear Stability of ALE Schemes for the Solution of Flow Problems on Moving Grids, Journal of Computational Physics, vol.174, issue.2, pp.669-694, 2001. ,
DOI : 10.1006/jcph.2001.6932
Aerodynamic force evaluation for ice shedding phenomenon using vortex in cell scheme, penalisation and level set approaches, International Journal of Computational Fluid Dynamics, vol.57, issue.5, pp.435-450, 2012. ,
DOI : 10.1006/jcph.2000.6614
URL : https://hal.archives-ouvertes.fr/hal-00768349
Low-Reynolds-number flow around an oscillating circular cylinder at low Keulegan???Carpenter numbers, Journal of Fluid Mechanics, vol.360, issue.4, pp.249-271, 1998. ,
DOI : 10.1017/S002211209800860X
Simulating flows with moving rigid boundary using immersed-boundary method, Computers & Fluids, vol.39, issue.1, pp.152-167, 2010. ,
DOI : 10.1016/j.compfluid.2009.07.011
Lift Enhancement of Flapping Airfoils by Generalized Pitching Motion, Journal of Aircraft, vol.47, issue.6, pp.1884-1897, 2010. ,
DOI : 10.2514/1.47219
Parametric study of an oscillating airfoil n a power-extraction regime, AIAA Journal, vol.46, issue.6, pp.543-561, 2008. ,
Compressible Navier???Stokes analysis of an oscillating wing in a power-extraction regime using efficient low-speed preconditioning, Computers & Fluids, vol.67, pp.26-40, 2012. ,
DOI : 10.1016/j.compfluid.2012.07.002
